Radiogareth
06-07-09, 03:36 AM
Can anyone tell me if I could swap sides for a standard exhaust manifold?
What I'm thinking is using a second standard N* manifold that hugs the block on BOTH sides of the engine, the outlet position does not matter much as in my application it will have a custom exhaust anyway. Or do the bolt hole pattern mean that it would have to go on upside down (which would not fit!!)?
Does that make sense??
My other option would be to nearly cut the pipes off the flange from the bigger manifold, fold them down towards the block, then weld up the cuts.
Thanks
Gareth
Thanks
Gareth
