whacked
07-15-04, 11:02 PM
Does anyone happen to have ECM pinouts for an 87 Eldorado? Thanks in advance!
| View Full Version : ECM pinouts whacked 07-15-04, 11:02 PM Does anyone happen to have ECM pinouts for an 87 Eldorado? Thanks in advance! whacked 07-16-04, 02:36 AM just in case anyone ever needs this http://www.fiero.nl/forum/Forum2/HTML/053169.html#lastpost whacked 07-16-04, 12:50 PM actually I'm hoping someone else has the pinouts ... looks like this post was for the body control module not the ECM blackcaddy 07-16-04, 08:22 PM Dont know if this will help but here you go. air divert sol control= blk/pink air switch sol control= brn power steering cut out= lt blu/orn vapor canister purge sol.=dk grn/yel egr solenoid control=gry efe relay control=gry/red fuel inj a control=blu fuel inj b control=grn trans temp input =wht mat sensor input =tan ground =blk/red or pnk/blk or blk/pnk map sensor input = lt grn 5volt reference = gry tps input =dk blu ground =blk/pnk cts input = yel trans temp switch=wht park/neutral input=orn/blk park/neutral input=orn/blk idle speed control= lt blul idle speed control= lt blu throttle swich input=pnk bat =orn bat =orn ign =pnk/blk crank input =ppl/white next 6 for cruise brake switch input=brn resume/acc input=gry/blk set/coast input=dk blu cruise on/off input=gry/blk or gry vent valve control=dk blu/wht vaccum valve control=lt grn fuel pump relay control=dk grn/wht fuel pump feedback=gry service engine soon= yel vehicle speed input=brn ac relay =yel cranking fuel enable=dk blu brake input=ppl vcc input=tan/blk fourth gear input=lt blu third gear input=dk grn/wht o2 sensor low=tan 02 sensor hi=ppl bypass output=tan/blk spark timing output=wht dist. reference pulse lo=blk/red dist. reference pulse hi=ppl/wht ground = blk/wht ground =blk/wht | |
