TwEnTy4InChEsTrOnG
07-15-04, 02:55 PM
what i have been told is that the 3/5 deluxe kit from mc gaughys can only be used in your escalade if you have 2wd..and would my 24s fit with this kit..has anyone done this kit on their lade..if so post pics and some info about this drop...also some pics with the 2/3..thanks alot.
invincible569
07-15-04, 04:31 PM
Do a search for infamouslade's Escalade on 24's and the 2/3 drop he put on. It looks very nice!!
T_Dogg8
07-16-04, 07:20 AM
a 3/5 drop and 24s would probably be too much. i believe you'll get at least some rubbing with a 2/3 drop, so a 3/5 would be a lot worse. if you want that much drop, get air bags.
i'm thinking of the same thing on mine, but it's awd. So from what I've heard its only for 2wd's. Good luck
i got 24's and the 2/3 kit and no rubbing and rides like stock cost $ 825 installed. If i could load a dam picture here i'd show ya.
Jungle George
08-08-04, 04:04 AM
Mine has the 2/3 deluxe drop, spindles in front and new springs in the rear...
jamesmbond
08-22-04, 01:33 PM
I just had my Ground Force drop kit removed and replaced with the McGaughys 2/3" kit. The ride is MUCH IMPROVED and now is softer more like the stock Escalade rode. The Ground Force 2/3" drop kit (torsion keys in front and springs in back) made the Escalade ride like crap.
My only problem now is that the McGaughys kit does make the front ride even lower (by about an inch) than the Ground Force so I get rubbing inside the fendor well even when hitting small bumps in the road.
I get a little bit of rubbing when turning sharp in the parking lots but the fact that the tire can travel right up into the fendor well worries me--hitting a bump at high speed (50mph +) sounds like it'll tear up something when they hit the fendor well.
Any suggestions or experience on this from anyone.
JB
T_Dogg8
08-23-04, 07:55 AM
what size wheels and tires?
jamesmbond
08-23-04, 09:18 AM
20" Boze wheels with 20" x 10" Toyo tires.
