View Full Version : 2002 Eldog
d442125
05-26-09, 11:22 AM
need info on changing plugs on 2002 eldog....why would labor take 2 hrs. to change them...can a cook do it?
Ranger
05-26-09, 12:35 PM
The plugs are under the ignition cassettes on the cam covers. The rear has an AIR diverter valve on top of the cassette that needs to be removed.
submariner409
05-26-09, 05:13 PM
Here's what you need to remove/check/clean........
Use ONLY ACDelco #41-987 Platinum plugs, pregapped to .050", 13 ft/lb of torque, no anti-seize. Change the plugs with the engine COLD.
kckranz
05-27-09, 10:44 AM
Eldog - You may not have the AIR valve on your Eldo:
http://www.cadillacforums.com/forums/cadillac-tech-tips/118874-how-identify-if-you-have-air.html
Ranger
05-27-09, 12:17 PM
Good catch kranz. Thanks.
