: Passenger turn signal bulb out
05-24-09, 01:34 AM
Passenger side front turn signal bulb out. Is this how to correct ?? (From another post.)
"I had to do was remove the tire and fender well to access the housing, then its just like any other bulb replacement (or socket replacement)."
05-24-09, 02:16 AM
yep, you may be able to get by with just turning the wheel all the way to one side to give you access, but I removed mine. The screws in the housing for the turn signal with be torx head screws. I just replaced my foglights with high performance ones. Its not difficult at all it just takes a few extra steps. Wait until you see how to replace the headlight bulbs. The front bumper cover and grill have to be removed.
Northern SRX
05-24-09, 06:29 AM
I've tried wheel turned and wheel removed methods on our '04 and found that removing the wheel dramatically sped up the procedure.
