: Do NS engines have an "air regulator"?
SoWorriedDriver
05-22-09, 05:48 PM
I went to a car service a week ago ... and they told me that the "air regulator" needs to be replaced ...
I searched this forum with "air regulator" keywords but found nothing.. :bomb:
Does NS engine has an air regulator? and if there is .. what are the symptoms of a faulty one?
devill 98
thank you so much..
STSS
05-22-09, 06:10 PM
Did they say it was on the engine? Are you located outside the US? Could it be suspension related?
SoWorriedDriver
05-22-09, 07:28 PM
Thank you STSS,
I don't know, It doesn't shift to lower gears easily, and it is bogging so bad. they say you need to change the air regulator. is there an air regulator in these engines? and are these the symptoms of a faulty "Air Regulator"?
And yes, i'm in the Middle East, Bahrain.
I don't know if it is the suspension.
Ranger
05-22-09, 10:17 PM
Never heard of an "air regulator". Might want to get some clarification from them. I'm sure they are using a non conventional term.
Raze
05-22-09, 11:03 PM
Pull your codes, pass temp up + ac OFF button for about 5 seconds with the ignition in the 'on' position (engine doesn't have to be running)...
Submariner409
05-22-09, 11:26 PM
I'll bet you dollars to doughnuts that the Bahrain car tech is referring to the old "vacuum modulator" which controlled full and part- throttle shifts in older transmissions.
Read up on pulling the Diagnostic Trouble Codes for your car......at the top of these main pages: "How to pull codes". You want the system for OBD-II.
If you find a code which refers to TCC or TCC Stuck Off, do some searching in here and Cadillac Technical Discussion or Northstar Performance. DON"T let the repair shop into the transmission yet !!!!
SoWorriedDriver
05-24-09, 03:43 PM
Thank you guys,
I'm sorry for not giving much details, making you guess.
I'm not quite good at technical terms at all. even non-technical terms.
Ranger, I expected to see your reply to "my" thread. Thank you so much. and yes they might used different terms.
However guys, I didn't get much details from them. it was hot and humid outside at noon.
The car doesn't start fast. and the RPM goes up and down. and it stalls or bogs (don't know if there is much difference between those 2 terms and which one is the right one) however, when I press the accelerator pedal.. it hesitates..
There is no gas smell at all.
Thanks to Raze and submariner409 .. I got the codes:
p0322
p1660
b 2150
they are current.. don't know if I did a good job in pulling these codes... or if they related..
and I'm sorry again for not giving proper details from the first.
SoWorriedDriver
05-24-09, 05:11 PM
sorry.. I think I should search for those codes using the search engine above as submariner409 said ... Thank you guys.
Submariner409
05-24-09, 07:17 PM
Don't ever worry about asking questions in Cadillac Forums. The more we all ask and answer, the more we know. Sometimes, answers to a problem that has been discussed at great length can be a bit tedious, but everyone benefits in the experience shared. Yes, we all get on our High Horse once in a while, but that's the "dammit factor", nothing else.
Ranger
05-24-09, 07:59 PM
The car doesn't start fast. and the RPM goes up and down. when I press the accelerator pedal.. it hesitates..
Check the fuel pressure.
