View Full Version : What size of Time-Sert I have to buy ?
Hlod
05-20-09, 05:24 AM
I have blown head gastet on 2000 seville sts (195 000 km on it)
IŽll buy M11x1,5 drills and align plate for northstar but what lenght of inserts to buy ?
there is two types 16,1mm and 22,2mm lenght.
Thanks
John
dkozloski
05-20-09, 09:50 AM
Time makes a kit or your car that includes the drills, tap, inserts, and alignment plate. Most guys are now using Jake's stud repair kit. http://d1.openx.org/ck.php?oaparams=2__bannerid=33807__zoneid=1188__cb =4048c923d9__oadest=http://www.northstarperformance.com
tateos
05-20-09, 06:43 PM
I did Norm's, and that worked fine, but today, I would do Jake's studs over timeserts, but to answer your question, your year engine has headbolts, and headbolt holes, that are 2 different lengths. I think it's the ones that are on the exhaust side that are longer.
97EldoCoupe
05-20-09, 08:35 PM
Actually the head bolts are equal length even on the 2000+. They're just deeper in the block/head on the lower row than on the top row. All 20 are about 1/2" longer than on the 93-99's.
tateos
05-21-09, 04:14 PM
Thanks Jake - so you mean the 2000+ heads are machined such that the bolts sit lower/extend further from the head than pre-2000?
Hlod
06-01-09, 02:59 AM
Thanks all for reply :)
Actually I have repair kit without but without inserts ;-)
IŽll remove heads and see what I need :)
THX
97EldoCoupe
06-01-09, 10:33 PM
Yes- the bolts are the same length, but the lower row of bolts sit deeper in the block.
