: 1996 FWB Rocker molding clips - issues
6.0 Litre
05-19-09, 06:39 PM
Anyone have an idea where to buy these types of clips or have an alternative idea on how to keep this molding from falling off?
The issue I'm having is the rear rocker molding behind the skirt - the arched looking belt clips are broken. My car is ugly with this missing chrome panel...
thanks in advance!
thefleetwoodguy
05-20-09, 05:41 PM
I have a bunch of them what #'s do you need??
6.0 Litre
05-21-09, 02:14 AM
Thanks for the response - One of Four the clips I need -
Part # 16615008 RROTR
the are four clips (Black belts if that make sense) total in the pic ( I need all four) - the tabs are broken either on top or on the bottom which holds the rocker - are those the ones you have?
many thanks!
thefleetwoodguy
05-21-09, 10:52 AM
many thanks!
yes have a couple sets, to make it easy to ID they are made with a # cut into each one, the best way for me to put a set together for you, look for those numbers, they are a single # like -"2" and so on, give me the four numbers of the ones you need, and I will put a set together
if you dont have them, I will try to match them up, but for times sake look for those single numbers cut into the part
also my e mail is captgale@msn.com thanks tfg
drmenard
05-21-09, 06:03 PM
Thefleetwoodguy is realy saving you, as he did me in the past... I got those clips at the dealer before and I get a good discount... and they were about $9 each... Dave
thefleetwoodguy
05-22-09, 02:51 PM
your set of clips are on the way....
and thank you Jim
6.0 Litre
05-27-09, 10:04 PM
and thank you Jim
Got the clips! Thank you again Jim.
