Moose123
05-19-09, 07:32 AM
I've posted this question to dick at Allante source but I'm curious if others have experienced this problem. What do you think? I'm looking for some help in diagnosing an overheating problem with my brakes. It started after I had my mechanic change the DOT 3 fluid while servicing the vehicle. Initially, the problem was with the rear brakes. The wheel covers got so hot you couldn't leave your hand on them. In fact, the left rear wheel was smoking hot. I took it back and they inspected the system, lubed the emergency brake mechanism, cleaned up the calipers and the problem seemed to be solved. I took the car home, went for a long drive and wouldn't you know the rear brakes were fine and but now the front wheels were very hot to the touch but not smoking yet. I brought it back in, and they said the cleaned the "slides" which had some corrosion on them. The pistons looked ok and the pads had good thickness. I'm not familiar with what the "slides" are. I never heard that term. The calipers, he said, are relatively new. He road tested it with no noticeable heat buildup. I took it for a longer test drive and wouldn't you know both front wheel covers were very hot again.
Can anyone provide any advice? Since it involves both fronts does it lean towards a problem with a component that serves both wheels? Did the changing of the fluid potentially contribute to the problem? Trying to find an inexpensive solution before my wife kills me or the car! LOL. Thanks in advance for your reply.
The mechanic has gotten the car running much better and I feel he has been treating me honestly and fairly. He said bring it back in an we'll certainly find the problem. I'm hoping I can point him in the right direction or take care of it myself.
