View Full Version : Nav DVD "Back-up" burn successful...
miscreant
07-14-04, 12:09 PM
Purchased the Mad Dog DL (Double Layer) Burner as posted in the previous thread. This is actually a rebadged NEC model with high ratings.
Purchased a DVD+R DL disc. Burnt the DVD, took about 44 minutes total.
Came in today, put it into a '05 CTS and drove around town a little.
Works great. Found nothing wrong with it. :D
T_Dogg8
07-14-04, 12:28 PM
how much was the dual layer disc??
Mbai2
07-14-04, 12:29 PM
That's good news! How's the Nav swap coming along? If for some reason you decide to give up on it, I'll be happy to take the unit off your hands :)
miscreant
07-14-04, 12:55 PM
They only had a 10 pack, 1 DL disc, 8 +R discs, and 1 +-RW or something like that, for $29.99.
Don't have it yet :crying: . On it's way.
darrelld
07-14-04, 08:48 PM
Thanks for that update, I'll head to Fry's the weekend.
Finesse
08-05-04, 05:52 PM
Ron,
What software did you use to burn a copy? I currently have Nero 6.0 and it has not worked on two verbatim (dvd+r dl) disk I used.
RGS
10-12-04, 02:32 PM
Ron,
I have the same problem as above.
Using Nero 6 and Verbatim DL discs.
Burned two discs and can read them in the PC DVD but not in the Nav unit.
The first one I burned would display the map on the Nav unit but got an error when I tried to verify the version #. The second DVD I burned was not recognized at all. The copies were from two different version map DVDs.
Any special settings to use with Nero 6? Can you post the process?
Thank you
