View Full Version : Slow speed turn rearend shudder/stutter
colbachlaw
05-14-09, 12:16 AM
Sorry if this has already been addressed, but my V seems to act like a locked differential when I make 90 degree slow speed turns.
The tires act like my old Scout II with a locked diff and shudder when I make tight turns.
It does not do this at parking lot speeds, but only at 10 MPH or more.
Is this normal?
Thanks,
Mike C
OldDrummer55
05-14-09, 03:38 PM
It doesn't sound normal to me. I found this statement in another thread, "Here's a twist on that. When I had the CTS-V and at the dealership discussing replacing the rear to solve the "grind at slow speed turns" TSB..."
Sounds like you have a trip to Vic's service dept in your future... :(
RapidRob
05-14-09, 07:32 PM
Is this normal?
Thanks,
Mike C
Not normal is my experience - did you have all your fluids changed recently? Could be they forgot to add the limited slip additive required for the rear diff. .. ?
Rob
colbachlaw
05-14-09, 09:05 PM
Rob,
I had all the fluids change out on my 3,700 mile trip home.
The place that did it in Vegas was a pretty Jiffy Lube with some sketchy looking guys.
I bet they did not add it.
I will have the dealer take care of it when they fix my tire pressure sensors and the low speed rubbing problem.
Mike C
Superior Cadillac
05-14-09, 10:46 PM
make sure you look at the tires.. I saw a case where the 2 rear tires were cut on a ramps while beeing served causing a rubbing issue on corners on the side walls and not enough rear end fluid added with the friction modifier..
Superior Cadillac
05-14-09, 10:46 PM
Mike if you drive it here I will fix it for you. BTW.
RapidRob
05-14-09, 11:50 PM
Rob,
Mike C
Good - I hope that takes care of it! I'm about ready to do the fluid change thing pretty soon now myself - I'm closing in on 1K miles, and plan to put AMSOIL products in, including their anti-slip differential addititive.
Good luck ..
Rob
colbachlaw
05-15-09, 02:45 AM
Scott,
Know any fixes for the traction problem I have?
You must have sold me a defective car, as the tires just seem to go up in smoke when I floor it.
Any idea if the new wagon is going to come out as a V after the first year?
I would love to smoke a 996 TT and an M5 with a wagon.
Mike C
Superior Cadillac
05-15-09, 12:45 PM
maybe you should tub the rear end and put some slicks on the car..
then you might break some half shafts.
