: OIL and FILTER?
avemaria
05-12-09, 08:51 AM
'96 FWB at 102K miles, what oil, (weight, synthetic vs. dino, brand ect.) and filter does the group recommend?
Thanks.
durrk johnson
05-12-09, 10:21 AM
royal purple....
haha... I wish I could use that stuff in my old ride...
96Fleetwood
05-12-09, 12:01 PM
I use Amsoil 5w30 and Amsoil filter #EAO23.
creeker
05-12-09, 12:42 PM
Thanks.
I use dino oil and NAPA oil filters on both my cars,the napa oil filters are Wix brand, good quality.
sven914
05-12-09, 12:54 PM
I use Castrol 5w30 High Mileage, and a FRAM filter.
The recommended oil weight should be on the oil cap.
jayoldschool
05-12-09, 01:27 PM
5w30 as the others have said. I use synthetic in all my vehicles. Castrol in cars with roller cams, and Rotella T for the old flat tappet cams. There are much better filters out there than Fram... check out the Napa Gold (made by Wix).
Highway Star
05-12-09, 02:40 PM
NAPA Gold or Wix filters as stated above. There's lots of good oils out there. Any good quality dino should get you 5K miles before a change. Much longer on syn.
jey
05-12-09, 06:19 PM
If you've been using dino oil this whole time it may not make sense at this point to switch to synthetic.
creeker
05-12-09, 10:05 PM
I strongly suggest you switch from fram filters,theres lots of info on them
in this forum,some guys have actually cut them open and have found that they are completly collapsed inside ,blocking the flow of oil into them.
Mr 5.19.
05-13-09, 01:14 PM
Dino, (your choice) as for the filter definitely WIX, both Napa/Carquest carry it.
C66 Racing
05-13-09, 07:35 PM
For those using AMSOIL, please consider the AMSOIL Preferred Customer Program (http://www.c66racing-synthetics.com/Preferredcustomer.htm) which allows you to buy at dealer wholesale, about 25% under retail. As an FYI, AMSOIL is partnered with Wix and Preferred Customers can also buy Wix filters at wholesale. :cheers:
