View Full Version : supercharger cover change?
backup
05-09-09, 09:51 PM
OK, the cover or top of the supercharger on my car is clearly different than the others I have seen or in pictures posted online. See pic. Was this a running change? Anybody else have this same cover? Or am I missing something? The part number on the label on the passenger side says part #12631035 with a date stamp of 2/2/09. That label also says made in Germany, but I thought Eaton made the blowers in the US? Maybe the cover is from Germany??
62Jeff
05-09-09, 09:59 PM
To be clear, you are at least missing the black plastic cover that normally hides all of the engine bits.
Or are you aware of that but asking about the metal bits specifically?
Your metal top definitely is different than the one in my car, an October 2008-built car.
http://i278.photobucket.com/albums/kk114/rcktman1_album/2009%20Cadillac%20CTS-V/Engine.jpg
backup
05-09-09, 10:03 PM
Yes I have removed both the front and rear black plastic vanity covers. I am talking about the metal top of the supercharger. On mine you can see it is flat and smooth, with a rectangular shiny metal plate near the back, all others I have seen have the embedded ridges cast into the metal cover. I assume this was just a running change in the cover design, but I find it a bit odd.
Razorecko
05-09-09, 10:20 PM
wait4me said the plate was a way to tell if the engine was overboosted. If it was overboosted that plate would bend out of shape. If you dont have the metal plate and just the grooves than i'm guessing you're pretty lucky
backup
05-09-09, 10:31 PM
I'm confused. For pics of others NOT like mine there is no shiny metal plate on the top of the supercharger and there is no place for one to be put on. Mine has a different design, without the embedded ridges, and WITH the shiny rectangular metal plate affixed into a recessed area with 5 screws. I have not taken that metal plate off to see what is under it, but it seems odd that they would make a cover design change and affix a metal plate with 5 screws in an area that previously was just the top of the supercharger.
Can anybody confirm the part number on the label on the supercharger cover? The part number on mine 12631035, cross-ref'd at gmpartdirect.com shows description: COVER but a list price of $1550! More than just a vanity cover.
62Jeff
05-09-09, 10:43 PM
I just pulled the plastic covers off of mine, and the label of my passenger side has the part number 12604851. It also says it is made in Germany.
backup
05-09-09, 11:23 PM
Interesting, 12604851 does not come up at gmpartsdirect.com. Wonder when they made the part change, and why? It seems more than cosmetic given the odd rectangular panel that seems to have been designed for some purpose. My car was built 4/17/09, I wonder if all of them now have this cover.
RapidRob
05-09-09, 11:33 PM
^^^ Here is the original thread on this subject - where wait4me suggests that the new cover/plate may be an over-boost detector ..
Here: http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/167666-intercooler-cover-change.html
I have the older style cover and my v2 was assembled in mid-February.
Rob
jwa999
05-09-09, 11:55 PM
Perhaps there's a change in the supercharger design to fix a problem w4m observed?
http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/168638-lot-less-black-soot-tailpipe-w4m-4.html#post1868620
"the dampner isolator spring"
Nutz
05-10-09, 04:34 AM
It's a super secret code for a drawing to tour the plant and assume ownership of the manufacturing facility! :stirpot:
http://tbn2.google.com/images?q=tbn:KZkCOjdLiiyXxM:http://www.videodetective.com/photos/046/000195_10.jpg
backup
05-10-09, 10:54 AM
Interesting. I want to pull that metal cover off, but I am worried there is some giant spring and about 50 pieces that will spring out from underneath if I take it off! That and one of the darn screws is directly under the strut tower brace and damn hard to get to. Anybody removed theirs? Still seems odd to me, and I am curious what this thing is really designed to do, why did they make the change.
wait4me
05-10-09, 11:32 AM
Maybe it was a panel to clean the top of the intercooler core. I havent gotten that new style here to tear into it and find out. In that spot is purely just a intercooler core. No springs, no suprises. All the seals are reusable so if someone took it apart, it wouldnt hurt anything..
As for the dampner isolator, that is in the FRONT of the blower assembly in between the snout and main unit.
4gear70
05-10-09, 12:09 PM
According to the Service Manual with an information cutoff date of 02/09/09, it is called an 'isolator pad'. The drawings seem to show it just bolting right over top of the ribbed section that is scene on the earlier units. There doesn't appear to be any other opening under this pad.
Razorecko
05-10-09, 12:26 PM
Is it possible that the intercooler underneath the plate is softer/thinner. That way if there is overboost than if the dealer pulls the plate off they will see telltale signs of warpage. Think of the plate screwed on the intercooler just as a "cover" for the "overboost checking area"
tedcmiller
05-10-09, 11:24 PM
My CTS-V looks like the picture that was provided by 62Jeff. It was obtained by me on Jan. 2. It was supposedly delivered to the dealer on Dec. 26. I suppose it was made sometime in Dec. 2008.
62Jeff
05-10-09, 11:40 PM
If you are really curious, there's a sticker in the driver's side door jamb, on the body, near the door sill plate that indicates the date of manufacture. On my Silver car, the sticker is silver with black writing making it a bit unobvious.
tedcmiller
05-10-09, 11:56 PM
62Jeff,
My car is black with the same silver label with black writing, and it confirms a manufacturing date of Dec. 2008. I guess I guessed correctly.
OldDrummer55
05-10-09, 11:58 PM
My V2 was manufactured on 03/09 and it has the new, non-slotted plate.
marktanner
05-11-09, 12:21 AM
Mine also has the non-slotted plate, and was manufactured 3/09 also. Must be a running change.
Short-Throw
05-11-09, 01:50 AM
Rob
Rapid Rob,
wait4me's suggestion is wrong.
It is NOT an overboost blowout panel. It IS an acoustic damper added to reduce lid resonance.
I just posted the correction in that thread as well!
tedcmiller
05-11-09, 01:21 PM
Good show Short-Throw. Multiple threads on the same subject are not new but certainly are a waste of everyone's time.
RapidRob
05-11-09, 07:49 PM
Rapid Rob,
Thanks for clearing this up Short-Throw. :thumbsup:
Rob
ctsbee
10-04-09, 05:31 PM
I just got a 2009 CTS-V and noticed the same thing about the isolator pad. The intercooler cover is sloted underneath mine. Personally, I like the old style intercooler cover; much cleaner looking. The isolator pad on mine is held down by socket head screws and looks like there is glue on the plate left behind from a label. I asked the dealership to show me their other CTS-V inventory and they all looked the same as mine. The executive administrator had a great observation it would be a good spot for an aftermarket vanity plate with a caddy insignia in gold!
nradcad
10-04-09, 09:27 PM
I'm sure this is normal but my cover gets insanely hot. As anyone else just decided to run with these covers off. I've seen references that the cover also helps reduce engine noise. If that's the case, I AM removing it. MORE ENGINE NOISE PLEASE!
