: Vacuum line routing?
eldorado1
07-13-04, 04:14 PM
I need some help figuring out what goes where on this 96 intake manifold... I labeled all the ports A-F in these 2 pics here. Also, is it correct that the port labeled "E" should be connected to the FPR? On my 95 manifold, it was connected to "C"... :hmm: Any help is appreciated. Thanks,
eldorado1
07-15-04, 12:40 AM
aaaaaaany ideas ladies?:yawn:
Ranger
07-15-04, 11:11 AM
A - Left bank (front) cam cover right (passenger) side
B - PCV valve
C - Evap canister purge valve (port next to electrical connection, right bank cam cover)
D - Power brake booster
E - FPR
F - runs to what appears to be a check valve? then to a "T" fitting then thru the firewall on the passenger side.
eldorado1
07-15-04, 05:10 PM
B - PCV valve
E - FPR
Okay, thanks for your help!
