Just curious. I am not a tire guy.. What is the widest tire we can fit on the stock rims? My car has very limited traction and I would like to stuff a larger drag radial out back if possible.
Or, perhaps, widen the rear rim to at least 9" (for 275s) and get the best of both. 275s are probably going to work much better on 9"+ rims, as they are designed to.Perhaps the reason for going with a wider tire got lost somewhere.
People plus size tires to get more hook. Not more handling. Now I am sure that everyone who went with a wider tire has WAY better g-meter readings than anyone else so don't get your panties in a wad. Whatever works for you is fine... your car. But the wider tire helps you get off the line. They won't handle the curves any better and they may feel a bit more loose depending how sensitive you are. A bulging sidewall is gonna give and sway more.
Great for a runway. Bad for mountain roads.
And the Bridgestone runflats...they were too wide as well? :hmm:Wow, sorry your experience was so bad. Mine has been amazing! Your problem was that Goodyear's are too fat. My Dunlops have no "roll-over" and way better grip then the 245's I had before.
If by change you mean, "anything but Bush," yeah I'll take it and thanks. Coming from a businessman, who's far more republican than democratic (although, I believe they should take the mere idea of "parties" and shove it up their arses...), this is a significant statement. That guy was, and is for that matter, a total moron of epic proportions.Glad you are on board with "change"...you can keep it.
