You can buy the braking surface only and they are cheaper than buying all new rotors. So you pay more up front, but you are trackin like a mofo and replacing rotors, it is a good route.
And if you are a sig mod whore like 154 :bouncy:, you can add Badass UUC 2 Piece Slotted Rotors
Actually that would be Badass UUC 2 Piece Slotted Rotors
And your just jealous! By the way, I have more but they only give me enough room to list the good stuff. I dont have anymore room to list the rotors even if I did get them : (
Luke
Will you still dole these out according to the waiting list or is it a first come first served basis? I don't want these bad boys to stock out on me.
I'd like to know that as well. I do believe however from what I've read in previous posts, that the real advantage is the ability to disapate heat. The guys who run the V on the track talk about the calipers turning gold from being cooked by brake heat. Even though the brakes are one of the strongest features of the car, these rotors would be a nice upgrade if you drive the car hard for long periods of time.
Looks like these are going to be $795.00 per pair. the blue color is UUC's "company" color, thats what they like to use. the advantage to the 2 piece floating design is less unsprung weight and much better heat dissapation. these will only be available for the fronts
Hey Naf! (sorry to threadjack luke but.. ) I thought you said you were sellin your V and were never going to slum it w/ us again! I remember reading some thread of yours stating that... did you change your mind? Did it fall through?
Just got the first set and they look great in person. I weighed one to compare it to a stock rotor and it is 7 lbs less (18 vs 25)!! anyone looking to try these for me at a fairly significant discount give me a call (I would prefer to talk price over the phone) 703-824-9670
UUC 2 piece full floating rotors are now in stock. $795.00 plus shipping. call me at 703-824-9670 to order. hear is a note from UUC on the advantage to a 2 piece floating rotor....
Floating rotors from UUC are suitable for street, track, or race use.
The "floating" design separates the central rotor hat from the outer disk friction ring, allowing the disk to expand radially with heat without a rigid connection to the central hat. As the rotor disk runs much hotter than the hat, the normal expansion can occur without distortion. This results in better braking performance and better rotor and pad wear. Additional benefits include lighter weight.
The parking/emergency brake hub on the rear prevents the use of the 2-piece design.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
