: recharge ac, what coupler?
JD2004
04-30-09, 02:55 PM
I am going to recharge the AC with r134a. I see that there are two AC couplers close to eachother in the engine compartment on the drivers side(left). Which one should I use? The one to the left or right?
Replies are appreciated!
carguy2009
05-01-09, 02:37 AM
Someone else might want to comment but I thought the fitting on the hose from the recharge kit would fit only one of the AC couplers.
conedoctor
05-02-09, 09:51 PM
Where did the other coolant go?
ericzoom
05-11-09, 11:18 PM
I'm not exactly sure on this vehicle which one it is, but be very careful hooking it up, because one line is the high-pressure line which can be dangerous if hooked up to the wrong one. Usually the line to use is the one that comes out of the firewall going to the compressor. I checked mine on my Mazda6 the other day, and it was the larger metal line on that car. I'm not quite sure on the Cad.
