View Full Version : Temperature Is Running High And Air Conditioner Is Blowing Cool Air But Not Cold
PACMANEJ
07-12-04, 04:48 PM
Help!!!!!!
joshuap
07-12-04, 07:30 PM
If you are speaking about the temp guage in the mirror, apparently Cadillac does not care. My father's is often off up to 9-10 degrees and Cadillac says it is working in proper specs to be off 10 degrees. My father bitched and told them that they are just waiting for a lawsuit when the gauge reads 41, and it is really 31 out...He told them not even to put the damn thing in if it is that much off...
hcvone
07-13-04, 09:27 AM
In the summer time if your sitting in traffic your temp will read higher, the sensor is next to the radiator, but when moving it should read pretty close to the right temp.
joshuap
07-13-04, 09:36 AM
Nope, this is while driving at 65 mph! We have seen several temperature signs, which show the temp to be consistently high. My truck does the same thing. I could understand if we were sitting still, but that just isn't the case.
T_Dogg8
07-13-04, 10:14 AM
i wouldn't always believe the temp. signs on places like banks. they're never right. mine is pretty close to always right on.
hcvone
07-13-04, 11:07 AM
TD is correct, we have 2 banks with temp display, believe it or not they are usually 8 degrees apart in what they display. You might want to check your temp sensor, it is up near the passenger headlight assy, mine had popped out of the hole it sits in and that caused it to have some strange temp readings, it was resting up next to the radiator, and I had a customers car that it was almost dragging on the ground. You have to pull the grill off to see it, and that is only a 5 minute job.
slk230mb
07-13-04, 06:43 PM
Last summer mine was broken, it was a wet and damp 60* day and the car said 125*, the sensor was shot, and since its been replaced, dead on temps for me.
Daryl in KY
07-14-04, 09:51 AM
What year is your Lade? My '00 seams to do the same thing, but I don't believe it's the AC. You can get a thermoniter in most larger parts stores to check the air temp coming out of the vents. Normally the AC temp is around 60 degrees when set on Max. When it's hot out and the interior is at 100+ degrees, it takes a while to cool all that leather down.
Sta11ion
07-14-04, 10:24 AM
I Have Had Terrible Experience With My A/c, On Idle It Is Not Cold Sometimes It Works Other Times It Doesnt. It Is Never Cold Enough, I Will Be Bringing It For Service For The Second Time At Royfoss.in Toronto
T_Dogg8
07-14-04, 10:38 AM
so far mine has worked like a champ. i don't use it a lot, but when i have, it works great.
