View Full Version : Burn Nav disc copy?
miscreant
07-12-04, 05:29 PM
Anyone have success in burning a copy of the nav disc?
j-w
07-12-04, 05:44 PM
I'll try with Clone DVD or some other tools I have to make a personal backup copy. I can't imagine it would be very difficult, regardless of any protection scheme.
miscreant
07-12-04, 06:04 PM
I remember reading that the problem had to do with the size of the DVD.
benjet
07-12-04, 06:21 PM
I don't believe there is a copy protection issue (but I could be wrong) the NAV DVD I have has about 7.5 gig of data on it. I have the older (what used to be standard) single layer ~4.7gig DVD burner, they now have dual layer burners (~9gig) available. I assume I can burn it to 2 DVD's but then neither would work properly in the car, but I would have the data backed up. Just never bothered to try, no real reason.
-Ben
miscreant
07-12-04, 06:33 PM
-Ben
Can you burn just the US data and not Canada?
Devil_concours
07-12-04, 06:36 PM
i have a dual layer burner if anyone is willing to let me try
benjet
07-12-04, 06:58 PM
Duh, I hadn't thought of that. I only have had the DVD out of the car once when I first got it. I will look into that.
-Ben
j-w
07-12-04, 07:05 PM
I remember reading that the problem had to do with the size of the DVD.You are correct sir!
Unless someone knows speficially how to delete any regions and not affect it's ability to work I think you'll need to burn with a dual layer.
miscreant
07-12-04, 07:18 PM
Okay, so you need a dual layer DVD and Dual Layer discs, correct?
benjet
07-12-04, 07:37 PM
I just went down to grab my DVD out of the car, stuck it in my PC, it's ~7.91g and doesn't have obvious sections for US/Canada. I'll look in at it some more and see if I can't figure out what parts to leave out.
Here is the Core info:
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID N/A Pressed DVD
Format Type UDF 1.02
Volume Name MAP_DVD
Application id
Implementation id Daikin U.S. Comtec Lab
Recording Date/Time (mm/dd/yyyy) 7/31/2003 9:43:57
Format Capacity 7.91GB(8.50GB)
Book Type DVD-ROM
Media Type DVD-ROM
Data area starting sector 30000h
Data area end sector 3F4C2Eh
Linear Density 0.293um/bit
Track Density 0.74um/track
Number of Layers 2
Layer Track Path direction (PTP) Parallel track path
Some of the above info will need to be known in order to make a working copy.
miscreant
07-12-04, 08:05 PM
How about this?:
http://www.compusa.com/products/product_info.asp?product_code=312929&pfp=SEARCH
benjet
07-12-04, 08:08 PM
How about this?:
Should work
darrelld
07-13-04, 01:34 PM
I have been looking for an excuse to buy a dual layer burner, please post back if this works.
miscreant
07-14-04, 12:05 AM
Success!
Atleast burning the disc. I was able to burn a copy of the disc to a dual layer disc. We'll see if it worked tomorrow! :D
