View Full Version : 98 NS Brackets
kingrobert
04-21-09, 02:30 PM
I was helping a buddy put together a 98 NS engine and he had an extra bracket on his bench he couldn't remember where it went. Looks like one of the accessory brackets but I couldn't find it on the web. I was wondering if any of yall knew which one it is. Thanks
tateos
04-21-09, 04:30 PM
Nothing seems to be attached...
kingrobert
04-21-09, 06:42 PM
I know, that's the problem, he had the whole motor takin apart and while putting it back together he wasn't sure which bracket it was
smooththg6969
04-22-09, 10:46 AM
looks like the bracket that connects the front of the motor to the right motor mount but I'm not sure because the pic is so small . it should go just to the left of the crank shaft with one bolt screwing it the front of the engine and and the other two on the side of the engine by the tranny.
tateos
04-22-09, 05:07 PM
I can't see the image - the thumb is too small, and no larger IMAGE is attached
[NortHStaR]
04-23-09, 02:26 AM
I think that its the support bracket for either the altenator or the ac compressor what ever one is lower I can't remember right now
kingrobert
04-23-09, 03:22 AM
Thanks yall sorry bout the small photo, here's a better one (hopefully lol)
smooththg6969
04-23-09, 02:20 PM
that's defiantly the motor mount connecting bracket. let me see if I can find diagrams
smooththg6969
04-23-09, 02:34 PM
Here ya go
http://i125.photobucket.com/albums/p70/smooththg69/mountbr.gif
Also only the 98-99 northstars that went into sevilles had this mount bracket so if its going into any other vehicle it may not be needed
kingrobert
04-23-09, 02:58 PM
I appreciate it, no wonder he had it extra, he got the motor from a junk yard and it's going into a deville. I'll have to let him know. Again Thanks
97EldoCoupe
04-23-09, 06:03 PM
You won't need that for a 93-99 Deville, only for the newer ones. That would have had to come from an SLS if you plan on using that engine in the Deville. The STS is the only other car to use that bracket in the pre-2000 era and that had the VIN 9 engine (different intake cams and valve springs).
kingrobert
04-23-09, 06:44 PM
good to hear I appreciate it
