View Full Version : how to fix error code 14???
gornati
07-11-04, 09:00 PM
ok, first of all, my name is Camillo and im from Lauderhill FL.
I have a coupe deville 81, with the V864 6.0L (368 cu. in. ) engine.
Runs fine but last week the check engine light came on.
When i run for 15 minutes the check engine light blinks and stay on.
I done the diagnostics in the climate control, and showed me error code 14.
it displays 88 - 14 - 70.
The only error i have is the 14 right?
What is this?
How to fix it?
Can i run the car with the error?
Thanks everybody for helping me out.
And by the way is it possible to know if the 864 feature is working in my car or not?
How?
thanks
gornati
07-13-04, 12:01 PM
nobody?
come on help me please...
by the way, today the error code 65 appear also.
any tips??
Daniel Almestica
07-13-04, 01:34 PM
look in the search and put in codes this should bring alot of good thing to help you(good luck)
Pianoman72
07-14-04, 07:54 PM
Hey man try this link
http://myweb.accessus.net/~090/81cfb.html
You def have a shorted coolant sensor.
Makes sense that you pulled a code 65 with that problem.
gornati
07-16-04, 10:43 AM
Makes sense that you pulled a code 65 with that problem.ok, to fix this i have ti change the coolant sensor?
IS IT HARD TO DO IT?
how to do it?
expensive?
thanks everybody
Pianoman72
07-19-04, 12:34 PM
Sorry man I don't have a caddy, I'm just a fan; don't know where the sensor is. I would go ahead and order a new one and while you're at the dealer you could just ask them to show you. Probably easier than trying to explain it anyway.
gornati
07-19-04, 04:52 PM
i already bought the sensor, but i have no idea where is located!!
anyone???
