: Priming the oil pump on a northstar engine
Moezy
04-20-09, 11:24 PM
Have u guys ever heard of priming the oilpump by adding twice the ammount of oil in the engine
creeker
04-20-09, 11:31 PM
I think it sounds crazy,what would happen to all that oil when you started the engine.
Ranger
04-21-09, 12:09 AM
Yes. The pump is not submerged and if it looses it's prime you have to submerge it. Put 16 qts of oil in it and run it. Rev it a few times then drain half out.
creeker
04-21-09, 12:16 AM
Wow!, who would of thunk,what are the indications of a dry pump?,what would cause it to lose it's prime?.
Ranger
04-21-09, 12:19 AM
The indications are no oil pressure and an oil pressure message telling you to shut down. Debris holding the check valva open would cause it. Not very common.
creeker
04-21-09, 12:21 AM
One more reason to do regular oil changes.
tateos
04-21-09, 05:39 PM
Ranger is correct for why...and how.
I did not lose prime when I did my HG project. I left the oil pump in place - also the lower end. Oil pan and heads and manifolds and chains and tensioners were off. I just left the indicated ignition module connectors disconnected per the FSM and cranked without starting for 20-30 seconds - then reconnected the connectors and it started right up with no oil pressure issues.
