: Gtech Pro Competition
Silver Baron
07-11-04, 03:42 PM
I am trying my Gtech Pro Competition (firmware 3.0) on the car's front lighter socket, but cannot get any RPM signal. Did anyone had this problem? :banghead:
Did you wire it differently?
StealthV
07-11-04, 05:00 PM
The voltage at the cigarette lighter may be too filtered for the G-Tech. To get around it, run a fused line straight off the alternator. The G-tech uses the AC oscillations in voltage from the alternator to determine the RPM. Remember to calibrate the RPM reading for the V as each car is slightly different.
Another shade-tree trick is to turn on the headlights to make the alternator work harder, producing a more "visible" signal.
Cal
07-11-04, 05:05 PM
I got it to register (a little sketchy but it logged my times) by holding it near the tach when doing it. Ask wild for some more tricks, he was the one who mentioned that, and I did eventually get it working. RPM was not exact, but you're talking about a device inside a car that has (arguably) very good sound insulation, and a rumbly cam.
StealthV
07-11-04, 05:29 PM
Forgot another one - turn on the rear window defroster in addition to the headlights to put a bigger load on the alternator.
wildwhl
07-13-04, 03:40 AM
Cal has it right. I managed to get a pretty good RPM signal by mounting the Gtech to the instrument cluster on the right hand side. Having the headlights on seems to help as well. It wasn't perfect, but good enough to get some consistent readings.
Good luck. (Dealer says car is done, I'll pick her up in the morning).
Shinkaze
07-13-04, 09:07 AM
Good luck. (Dealer says car is done, I'll pick her up in the morning).Why can't they just mount to the white Tach lead off the PCM just like every other RPM device out there? This sounds like a bit of a kludge. :suspect:
wildwhl
07-13-04, 01:56 PM
I believe the goal is to make a user friendly, plug and play device that doesn't require any hardwiring. I've made it work quite well by doing as outlined above (at idle, the RPM's misread but anything over about 2K looks correct). Kind of a cool gadget in that all you have to do is place the suction cup mount where you want it, plug it into the cigarette lighter, enter a couple of numbers and PLAY!
Shinkaze
07-13-04, 02:30 PM
Bah Humbug! Screw simple. Here is a picture of my nitrous system.
http://www.shinkaze.com/images/wire-storm.jpg
Shinkaze
07-13-04, 02:32 PM
Oh... and the user side of that panel....
http://www.shinkaze.com/images/glove_compartment01.jpg
wildwhl
07-13-04, 06:13 PM
Oh, so we want to discuss simple projects, do we? :)
StealthV
07-13-04, 06:16 PM
That looks like a 911 rear-ended a motorcycle. :)
wildwhl
07-13-04, 06:35 PM
Tangent and thread jack.
1208 lbs. with my 170+ in the driver's seat.
130+ hp.
0-60 RFN (Right Friggin Now)
Whell spin in any gear, but no hop! :)
Shinkaze
07-13-04, 08:14 PM
Man are you hiding Bike under that Volkswagon? :D
DgtalPimp
07-13-04, 08:21 PM
What the hell is that (http://www.bangedup.com)?
Dgtal (dgtalpimp@pimpdaddy.com)
StealthV
07-13-04, 09:55 PM
You've been served.
http://images.southparkstudios.com/media/images/805/805_image_04.jpg
A classic South Park episode, almost as funny as "Good Times with Weapons."
Back on topic, Silver Baron - did you get the Pro Comp to work? If so, results?
What ever happened to the send the Pro Comp to a friend and so on and so on idea?
