mtflight
04-15-09, 06:36 PM
This isn't as good as SL1CKs, but it is for the 2000+ which is quite simpler!
It also shows the IAC valve, which is so easy to take out and clean, but so expensive to replace!
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0679.jpg
Behold... my clean engine bay. It's more fun to work on a clean engine. I like to keep it clean!
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0680.jpg
To remove the air intake duct, simply unscrew the two screws on the air filter housing, and
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0681.jpg
unscrew the slotted bolt holding the intake to the TB.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0682.jpg
Here is the IAC plug, two phillips screws hold it in.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0688.jpg
When you take it out (After unplugging it) here is the port hole, clean this well too.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0689.jpg
Here is the IAC valve, and it's two fastening screws. I cleaned it with electric parts cleaner, so if any of the solvent leaks into the electric motor or windings, it doesn't harm them as it's non-conducive.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0690.jpg
This is a dirty IAC valve. The shaft is supposed to be shiny metal, not black soot.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0687.jpg
Remove the duct work (unplug MAF sensor plug first)
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0691.jpg
Dirty TB
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0693.jpg
Spray it with the TB cleaner. I use a Toothbrush as well.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0694.jpg
After the cleaning, the edges are clean and the back of the throttle plate (WOT, shown here) should be clean, as well as the mating area with the TB. Don't worry about the stuff further in, that'll dirty up in no time and does not affect operation.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0684.jpg
not everything that shines is gold--this is platinum jk :histeric:
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0698.jpg The rags will be really dirty.
http://i66.photobucket.com/albums/h267/mtflight/dhs/tb%20and%20iac/IMG_0699.jpg
The heroes of the tale! The electric parts cleaner saved my EGR valve on the Eldorado ETC I owned... u can use regular TB cleaner, but allegedly if you get the electronic windings wet with it, it can become toast! I used the Electric parts cleaner on the $349 retail price IAC.
Dirty TB
