caddy4yaass
07-10-04, 12:31 PM
13 o2 not ready 2. 26, shorted throttle switch 3. 27, open throttel switch 4. 34, map signal to high 5. 37, shorted mat sensor 6. 38 open mat sensor 7. 44 lean exaust and finaly 52 which is the battery reset. now i know that most of these are related but how do i even start to look for the problem. were is the mat sensor?? and were is the map sensor. and i know thats what caused my lean exaust. and were is the o2 sensor there is just so much crap under the hood i dont know were to look??
illumina
07-10-04, 01:09 PM
the MAP sensor is the little square thing that is raised on the rear/right valve cover...the MAT (manifold air temp) sensor is located behind the alternator, towards the firewall or the car,looks like a spark plug sticking out of the inatke manifold, with a wire connected to the top of it. the 02 sensor should be on one of the exhaust manifolds...not real sure of exact laocation for you car though. i will dig some pics out if i can.good luck.illuminaP.
caddy4yaass
07-11-04, 01:42 PM
thanks for the reply.:cool:
