View Full Version : Drilling through firewall in my '77 deville
Tzd1310
04-12-09, 02:58 PM
So now that my head unit has been installed in my coupe...
http://i735.photobucket.com/albums/ww352/tzd1310/0410091646.jpg
...I am working on setting up 2 12' subs in the trunk. Ive got the rca cable all set and the last thing i have to do is find a hole in the firewall to run the 4 gauge power cable through to the battery. Are there any stock holes (preferably) on the right side? or am i going to have to drill one. And if i have to drill is there any particular spot i should choose?
Any help is appreaciated, Thanks.
csbuckn
04-12-09, 11:28 PM
I usually go through on the driver side. I use the steering shaft as a reference when drilling. But I think I got a 4 gauge wire through without drilling. The right side may be harder cause its packed over there.
jayoldschool
04-13-09, 02:09 PM
Why not just run it along the frame under the car, then up into the trunk to the amp?
csbuckn
04-13-09, 10:48 PM
I've heard of people doing that with 0 gauge but its too expensive to have exposed like that, IMO. I drilled to get my 0 gauge rope through. It actually fit along the side of the car without being exposed but there was already wires and some type of cover that the wires fit into. I dont know about a 77
Tzd1310
04-14-09, 12:33 PM
the only problem is the battery is on the right and I don't have enough wire to go through the driver side firewall. I'd rather not rig it underneath if I don't have to but I still need to find a way through
csbuckn
04-14-09, 02:24 PM
Some wires for the ECM go through on the passanger side(at least on the 90), maybe you can get through with them.
Tzd1310
04-15-09, 01:47 AM
I'll frtry that, I'm going in from underneah where should I look for these wires?
jayoldschool
04-15-09, 10:25 AM
The factory harness passes through the firewall right under the heater. Find that connection, and drill a hole to pass though. Look under the glovebox.
