: Touch Up paint question
04-11-09, 11:29 AM
Hi, is the touch up paint (alone) all I need for a Pearl White Diamond 'Lade or is there a clear coat touch up bottle, etc. etc. that is also needed?
Has anyone touched up paint scratches, etc. on a Pearl color? Is the procedure the same as a regular color?
04-11-09, 12:40 PM
I used a GM white (338)first, then applied WHITE DIAMOND (93 8933 White Diamond touchup , then applied the CLEARCOAT98 800J White Diamond Topcoat touchup. tedious , but effective esp on the plastic trim pieces.
duplicolor dot com
04-11-09, 05:54 PM
To look the best, you need to start with the base white color, let that dry, then apply the translucent pearl over that. If it's a very large area, you'll have to finish up with a clear to get the gloss back up. That's why it's called 3-stage paint and why it's a factory up-charge.
04-11-09, 06:18 PM
go to the dealer get the base white and diamond clear. Cost me $35.
