View Full Version : Anyone have any idea how to stop the paint chips
chris1268
04-08-09, 12:54 PM
Is anyone else having issues with paint chip on the rear doors? I waited a bit to long to get the clear bra on the front becuase I was trying to find someone to do the entire hood and of course now have chips everywhere on the hood. 3k miles and I now hate Black paint. Anyone still deciding on a color - be very weary of Black.:rant2:
anonfrank
04-08-09, 01:14 PM
Where on the rear doors are you having issues with paint chips? That will be very helpful as if it's a common problem, the problem areas can be covered with Xpel or 3M clear bra material, I would think.
Just asking...I'm planning to do a clear bra in the near future from my favored mobile installer.
thebigjimsho
04-08-09, 01:18 PM
wrap the whole mofo...
chris1268
04-08-09, 01:23 PM
The factory actually installed a small piece on the bottom front corner of the rear tire well and bottom of the door itself. They obviously knew that was a problem area. The chips are coming all around that general area. Hope that helps.
demorgan59
04-08-09, 03:44 PM
Google "auto paint chip protection" and you'll get all the product you can handle.
CASEY122457
04-08-09, 08:04 PM
Try www.body-skins.com He will solve your problems.
Shankenfelter CTSV
04-08-09, 09:02 PM
read this thread.... Plastic Surgeon is fantastic, and he can do your whole hood. He did EVERY Panel on my Lambo LP640 and my entire Gallardo Spyder nose.
http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/166514-surface-mods-first-35-tints-clearbra.html
nc09v2
04-08-09, 09:35 PM
I'm in the south, we don't have the salt/sand that you've likely been driving through, but I used to live in the northeast and remember how winter was very tough on car paint.
I've gotten a few chips on my black V, and aside from the clear protection options, I've had very good results as follows:
1. Use GM (or Duplicolor) black touch up paint, carefully fill in each scratch as needed until it is level or a bit higher than level with the surrounding surface. Let the paint dry for 30 - 60 minutes (70 degrees).
2. Be sure the surface is absolutely clean and dirt free.
3. In the shade only! Use Meguiars #9 polish and a soft polishing cloth, rub gently back and forth over the touch up spot(s) at varying angles. They will shortly become almost invisible and blend in with the surrounding paint.
Add touch up and repeat if you polish too much out of a scratch.
4. Wax the entire panel you worked on with good quality wax.
You will be amazed at how easy the black is to match and work with, aside from the need to wash it frequently, it is pretty touch up friendly vs. colors where touch up match gets more tricky.
The above being said, the "soft" paint formula that GM still uses is probably my biggest irritant with this car to date. The paint on my Benz is lite years better as far as chip and scratch resistance goes, they use a "Nano" technology that they claim hardens the paint 250%. It works, and GM should use something comparable on a car at this price point if anyone is listening.
chris1268
04-09-09, 11:16 AM
Actually I already talked to Rick and he won't do a full hood either.
chris1268
04-09-09, 11:26 AM
Thanks - I put a call into him today. I'll let you know how it goes.
Kadonny
04-09-09, 11:33 AM
Chris,
I posted this awhile ago too. My car did not see the winter action yours did and I still can see where the rear door are going to get beaten up.
I plan on clear bra-ing the hood, front clip and rockers and lower doors. I just have to get it done.
Florian
04-09-09, 01:51 PM
dont drive on rocks....problem solved.
F
Richie18
04-09-09, 05:37 PM
F
Hard to do if you live in the midwest or farther north.
Florian
04-09-09, 11:05 PM
I live in the Midwest...no problems here.
F
chris1268
04-10-09, 10:32 AM
F
Unfortunately I don't have private roads like you must to keep the roads clear of pebbles while driving. I hope your luck continues.
Florian
04-10-09, 12:14 PM
me too! YAY
F
Ketzer
04-10-09, 01:51 PM
The only manuf that lists a fairly complete "kit" for our cars is Xpel. Just the pre-cut pieces is over $1k... uninstalled.
The other two major players don't list a pre-cut kit. Yes, I know the pro shops can take a blank sheet and custom fit. I've also read on other forums of nightmares where the finished product looks like Freddy Kruger and Edward Scissorhands did the install... after a few beers.
Jeff-
thebigjimsho
04-13-09, 03:23 PM
They might not have the templates available, but doors and fenders will be very easy to fit for a pro. The front end is where the issues lie...
OldDrummer55
04-13-09, 04:54 PM
Ventureshield has a pattern for V2s. Sounds like we should also do the lower doors and rocker panels.
http://members.invisiblepatterns.com/pattern_search.php?&region=na&type=1&year=2009&make=2884&model=27605
thebigjimsho
04-13-09, 09:06 PM
very nize...
