: dtv box conversion from ac to dc. HOW?
mrgoodbar67
04-07-09, 10:22 PM
i wanna have a tv tuner in my car.
unfortunately...old tv tuners are only anlalog which we all know will be obsolete in june.
how can i convert the dtv boxes that are for sale from ac wall power to dc power for cars?
i know its possilble cuz a guy on avic411 forums did it.
iowasevillests
04-07-09, 10:35 PM
My answer would be don't, instead buy a low output car power inverter, and convert DC to AC instead, the power signal out of the inverter isn't as clean as what you see in a wall outlet, but for running a tv tuner I would think its more than adequate, plus now instead of having a bizarre TV tuner that is useless for any other use you still have a functioning tv tuner, plus a power inverter. I've toyed with the idea of permanently wiring an inverter in my car, but for now it just sits in the glove box and I pull it out when I want it.
mrgoodbar67
04-08-09, 01:03 AM
ok sound like a better idea.....
where do i get one and what does the install entail?
iowasevillests
04-08-09, 01:42 PM
You can pick up a power inverter at most any electronics store, big box retailer, car accessory catalog or camping place. Price will vary with power(Watts), I think I gave 65 bucks for my 300W inverter at Nebraska Furniture Mart last year. For what you're going to be running off it installation should be simple....plug into cigarrette lighter, plug tuner into inverter. If you're running something that requires more power(mine is greater than 100W) you need to hook the inverter up directly to the battery as the wires supplying the Cig lighter are too small of gauge to handle that much power. But I can't imagine the tuner drawing that much juice, most laptops are 60-90 Watts, so you should be fine if all you're wanting to run is the inverter.
Now its up to you to determine how much work you want to do in order to hide the inverter, you can leave it set on the floor when you want to use it, or you can try and tuck it away in a console, under a seat etc, all depends on who much effort you want to spend on it and how often you plan on using it.
mrgoodbar67
04-08-09, 03:29 PM
well i like clean installs..so ill put alot of effort.
ima look online for it now.
mrgoodbar67
04-08-09, 06:35 PM
Ok, i found allot of invertors..but they have the dc (cigarette lighter) outlet connection.
Can some one tell me how i can make the connection more permanent?
Do i just cut the cig lighter outlet connection off and then splice the wires to acc switched power and ground?
If so i can do easily..if not then tell me how.
Thanks
iowasevillests
04-08-09, 08:00 PM
Mine is an APC model and it came with 2 sets of wires, one set with the male cigarette lighter end for loads under 100W, the other was a heaver gauge wire with some decent small spring loaded clamps for clamping directly onto the battery. If you're going to wire it up fairly permanently I would probably look for a wiring kit similar to what you wire up a lowered powered amp with for the hot, you can pull ground from most anywhere(just make sure you clean the paint of it its painted), AND MAKE SURE TO FUSE THE HOT! If you don't fuse the wire coming from your power connection you're at risk of starting your car on fire if the insulation gets chafed and shorts out. If you use an amp wiring kit the inline fuse of the appropriate power should already be in installed. Now where you pull power from is up to you, if you want power all the time run it to the battery, if you only want power to it when the car is on find an available switched outlet.
jbwebster601
01-15-10, 07:44 AM
Thanks
Hey there...
I am going thru the same idea and got stumped too. Then i can across one on ebay, ATSC HDTV TV Tuner Receiver /Converter For Car(just buy an amp kit to hook it straight to batt., hardwire a switch on the dash to turn it off. I have hardwired a Ac/Dc converter to my dome light switch in a Ford Crown Victoria before. It only came on when I manually turned the dome light on.
My only downfall is, I would like to have one with FM built in the tuner so I can use just a screen where my radio is, hide the tuner in glove box or trunk, and add a 80gb Media Hard drive unit to play mp3, video, and photo on the screen. Good Luck, PM me if needing more install help.
eyekandyboats.inc
01-15-10, 09:56 AM
LOL this is SO funny... i JUST bought a DTV tuner :) lol will post when i comes in
cadi509
01-19-10, 12:04 AM
This is a fairly easy install and I'm gonna do one I get my pioneer 4100dvd, I already have a power converter 15amp 300w which I bought at bestbuy, and a power outlet (cigerette lighter) from schucks that can be hard wired in, the only thing I'm stumped on is where would be a good place to put an antenna that will get decent receptio, I'm either gonna put the dtv box in the glovebox or mount in under the glovebox in a good spot. It'll be cool to watch TV from my car lol
