View Full Version : Will these rims fit / work on my Escalade?
pcguy760
04-07-09, 10:58 AM
Hi, I am getting a good price on some Boss Motorsports 313 Chrome rims for my 02 Escalade. Although the seller told me it would fit I thought I would come and verify with you guys as well. Here are the specs...
Wheel Size : 24x10
Bolt Pattern : 6x5.5
Offset : +12mm
BSM : 5.91
BTW, what is "BSM" and is it correct for my vehicle? Thanks.
H0TWHLZ
04-07-09, 01:08 PM
You should be good to go bro! Normal bolt patter for an 02' Lade is 6X139.7....well at least it is for mine ;-) The 139.7 is in milimeters, if you do a quick Google search on how many inches are in 139.7mm, you'll get this result:
139.7 millimeters = 5.5 inches
Hope this helps.
H0TWHLZ
04-07-09, 01:17 PM
Also, I believe that the BSM is for backspacing....used for mounting. Give a call into a tire shop, they should be able to tell ya right quick.
pcguy760
04-07-09, 01:50 PM
Ok great! So I do not have to really worry about the "BSM" then?
H0TWHLZ
04-07-09, 04:22 PM
As long as you think the wheelz look PIMP, then I don't think you have any reason to care about the BSM.
ZaC851
04-07-09, 06:10 PM
wrong backspacing could cause the wheel to poke 2 inches past the fender, or the opposite of that.
pcguy760
04-07-09, 07:26 PM
Ok well then am I okay with a BSM of 5.91 inches?? :o
