: high idle
04-04-09, 04:12 PM
ok i got a high idle i thought my air flow sensor is bad or Idle Air Control valve i got a few codes so maybe someone could point me in the right direction to why i have a high idle so i can get the right part. the car is a 97 eldorado (i put the ones in bold i thought could be causing the problems)
pcm p0102 h-Mass Air Flow (MAF) Sensor Circuit Low Frequency
PCM P0153 H-Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
PCM P0404 H-Exhaust Gas Recirculation (EGR) Open Position Performance
PCM P0405 C-Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
PCM P0507 H-Idle Speed High
PCM P0603 H-Control Module Long Term Memory Reset
PCM P1578 H-BBV Sensor Circuit Low Vacuum
PCM P1645 H-Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
ACM B1314 C-Evaporator Inlet Temp Sensor Open Circuit
ACM B1315 H-Evaporator Inlet Temp Sensor Short Circuit
PZM B1552 H-Keep Alive Memory (KAM) Error
PZM B1558 H-BCM EPROM Checksum Error
PZM B1983 H-Device Power Circuit Low
PZM B2719 C-CTD-Trunk Tamper Switch Fault
PZM U1088 H-Loss of Communications with SDM
RFA B2560 H-RKE Message Validation Error
MSM B2107 H-Front Vertical Down Switch Failed
MSM B2118 C-Front Vertical Sensor Failed
MSM B2120 H-Lumbar Up/Down Sensor Failed
MSM B0856 H-Battery 2 Out of Range
MSM B1983 H-Device Power Circuit Low
04-04-09, 04:13 PM
also the idle is high at start up also alot of this happened after i cleaned my throttle body
04-04-09, 04:41 PM
Check your work. make sure that the linkage is not binding. Maybe clean it again. Pay attention to the throttle plate perimeter. That is where it seals against the TB bore. Also check the over pressurization valve at the other end of the manifold.
04-04-09, 07:37 PM
it was the air flow sensor
04-04-09, 07:42 PM
MAF sensor? How did that cause a high idle?
04-04-09, 10:41 PM
Nope......that was an old History code. Not the problem.
Should have cleared everything and started from scratch and completed a week of driving cycles. (Unless this code list is from after the MAF change, but unless you mechanically break a MAF unit, they're pretty reliable.)
The EGR codes are suspect.
How high was the idle at startup ?? 1,250 is normal for 20 seconds.......
04-05-09, 10:13 PM
yeah it was when i was cleaning the throttle body some of the cleaner got on it. i replaced it and no more high idle car runs better too
