View Full Version : code questions please...
illumina
07-08-04, 11:14 PM
i am going to work on a 1994 sedan deville with the 4.9 engine, but im not real sure as to what the codes on this car means, if they are the same as my 91 w/4.9 let me know...here are the codes for the 94'
p012...
p039...
p053...
p098...
i039...
i052...
a012...
a037...
any definitions would be greatly appreciated.
chuckdobbins
07-09-04, 12:25 AM
I039 Loss of Road Sensing Suspension Data
I052 Keep Alive Memory Error
A012 Low Side Temperature Sensor Circuit
A052 Keep alive memory error
P012 No Distributor Signal
P039 Torque Coverter Clutch/Viscous Converter Clutch Engagement Problem
P053 Distributor Signal Interrupt
P098 High RPM P/N to D/R Shift Under ISC
your probably reading those off the same site that i am, but thats just what i understand them to be. where you go from here i havent a clue on those. atleast you can tell that many of them are related, if not caused by the same thing.
illumina
07-09-04, 12:36 AM
thanks for the info. this car is idleing eratically, then dies out, but starts right up again. i noticed the ISC motor going bonkers too, i think that has something to do with it. the owner claims he had a new distributor put in less than a year ago, but im not sure on that. if so, they could have messed up that job (if i didnt do it, it wont work right!:D). i think the p98 code also tell me there may be a problem with the ISC motor, so i think i can fix her from that. thanks again illuminaP.
