: Service Stability Light
04-01-09, 04:49 PM
I know this issue has come up in the past but all the old post have to do with the wheel hub assembly. I just replaced both front hub assemblies and the problem with the ABS kicking in when braking no longer is a problem. My service stability light is still on and I hooked it up to OBDII and it didnt put out any codes.
Do you guys think the rear hubs need to be swapped out as well?
Do you think the ABS pump is bad?
Any ideas, input or help would be appreciated.
Thanks, Mike
04-07-09, 09:15 PM
Nobody has any ideas on this?
Are they ABS sensors on the rear hub? Or any other location then the front hub assemblies?
If it is the ABS pump is it better to get a new pump or have the old pump repaired?
