: 1999 Seville SLS hard start P1350/P1375
jdshafe
03-29-09, 06:11 PM
I have a 1999 Seville SLS that has been intermittently hard to start and when it is hard to start it will bring up a P1350 and P1375 code. I have changed both crank position sensors and the cam position sensor. I have also changed the fuel pump and filter. We love this car, but I am beginning to fear leaving my wife alone with it. It does always start eventually , but I know the day will come that she will be calling a tow truck.:confused:
Submariner409
03-30-09, 03:09 PM
If you look at the sticky thread just above this one you'll see a "How to pull codes" and "got codes ? Look here" thread. Open it and click on the url with OBD-II in the address. Scroll down to your P codes.
jdshafe
11-15-09, 01:54 PM
Well, we finally got that issue cleared up. We ended up finding the one of the plugs going to the crank sensor was damaged and not always making good contact. Thanks for help on this.
tateos
11-16-09, 10:36 PM
Thanks for the update. Supposedly, you only need 1 of the three sensors you mentioned to run the engine. How did you find the problem? Did it have to fail completely?
jdshafe
11-20-09, 11:09 PM
My son was going to an automotive technology class at our local junior college and he had it at school on the lift and was able to inspect everything good and found the problem.
