: what bulb type is the small corner bulbs in headlight assembly?
cocaines
03-28-09, 02:57 AM
as the tittle i want to replace those bulbs with leds in my headlight housing but have no clue what bulb types they are.... i am looking for something more to match my hids that i have....
pgw85706
03-28-09, 09:30 AM
I believe this is designated as the park lamp bulb and the OE replacement is Sylvania 3757 clear.
lreddiablo
03-30-09, 06:10 PM
Can anyone confirm this, anyone actually changes this bulb?
leija_01
03-30-09, 07:25 PM
i believe its a 194, I was going to replace mine with LED BRIGHT WHITE, but haven't done so yet...ha.
silver2kws6
03-31-09, 01:49 AM
the small bulb is 194 i was going to change mine as well but had a hel of a time trying to find out how to get to it !
cocaines
04-08-09, 12:31 AM
i got 2 different answers 3175 and 194... i already purchased the 3175 led bulb but i dont want to pay for my bumber removal unless i am for certain the bulbs will work
sweetdivel
04-08-09, 02:22 PM
They are the same as the rear license plate bulbs and the ones in the side of the bumpers. I did change them but changing them requires lots of time and small hands.
lreddiablo
04-09-09, 05:20 PM
So 194s I believe
Unique Distributing
04-13-09, 09:48 PM
just came back from canadian tire right now and its called a Marker Light. and it is in fact a 194LL Bulb. I just turned on my car today and looked and saw that little bulb was out and went in and they told me. so 194LL is the answer
cocaines
04-14-09, 01:19 AM
how much did they say they will charge you to change them out... when mine first blew in 2007, Royfoss, the dealer charged me $167 CAD after taxes to change that one light. if i knew how to do it myself i would do it, since i order some 194 HID white led from ebay. because one of my "marker" lights blew out last week.
I am starting to loose respect of Royfoss, they charged me $480 tryin to fix my passenger fog light over the span of 2 years and only got it to work for 24hours after they fixed it.... today i took out my fender linning and found that there was a short in the wire, got some eletric tape and viola its fixed.
so i am not willing to give those guys another $167 to change my marker lights.
lreddiablo
04-14-09, 05:35 PM
Wow, my local proshop changed my fogs for free when they were changing my exhaust. If the car is hoisted above your head it is possible to reach in and change the fogs without removing anything. I had them install chrome coated bulbs that have a more desireable amber light than the factory bulbs. Only took them a minute about for each bulb once the car was raised
Unique Distributing
04-16-09, 02:37 PM
ya even tho Royfoss is close to me i dont deal with them. i usualy deal with a local shop around here called Aurora Auro. they used to be good but i didnt change it yet so i didnt know it would be that hard to fix
jjsocrazy
04-16-09, 04:24 PM
OK according to this the license plate bulb is 2825 which I have installed all ready in my license plate, and then another person said for sure it is the 194 Bulb. So I guess go for the 194 bulb?
Thanks
Joe
silver2kws6
04-16-09, 04:27 PM
Thanks
Joe
I just changed mine to leds its 194
cocaines
04-16-09, 09:33 PM
did you do it yourself or did u take it to an autoshop... if u did it by yourself were able to get to it without removing the front bumper, and if so how.. a walk through would be nice if you took that route...
DTS_BOI
04-18-09, 12:15 AM
Someone please advise how to change the fogs. I always thought you had to remove the bumper???????
silver2kws6
04-18-09, 12:29 AM
take ur inner fender wall out and its a easy swap !!! take ur wheels off too that will make it super easy !!!
lreddiablo
04-20-09, 04:52 PM
or if u can use a hoist for a bit, raise it up above your head, and then its not too dificult to reach up from under the car
