: Any idea what I should pay to get the evap solenoid replaced ?
03-27-09, 02:04 PM
Got the "check gas cap" message and the garage said the evap solenoid was bad. Just curious how much cash I should bring......Again :crybaby:
03-28-09, 08:18 AM
The labor should be about 20 minutes since the solenoid is right on top of the motor. Held on by one bolt, a vacuum connector and electrical connector. That job should be a 2 on the DIY scale.
04-01-09, 01:10 PM
Definitely DIY, a dealer trip is an inconvenience and they'll probably charge you at least $100 in labor to do it.
Are you sure its the purge solenoid that went bad? I had the vent solenoid go bad, that was also an easy one to do, though a bit harder than the purge solenoid on the engine. Had to lift the car and take it off of the canister beneath the rear seat. Still something I'd never pay a dealer to do.
