: How to remove overhead bezel?
n7don_srx
03-21-09, 09:58 AM
In searching I find there is a switched 12v source at the overheading rear wiper switch and to the rear view mirror. It isn't obvious how to remove the bezel to get at the wiring. I did remove the snap-in plug located in the bezel's center but didn't see any screws, etc. I didn't want to do much prying and risk cracking the plastic. Any info on it's removal would be appreciated. It's an 07.
srx05v8
03-21-09, 05:23 PM
for 05, you just stick your fingers in and pull it out. There are quite a few firm retainers inside, so you have to use some real force (but don't overdo it - meaning if you break anything, don't blame me:-). The trouble I had was to put it back on. make sure the metal retainers are not left in the hole (chances are they will as they are sharp-pointed and are really firm. I had to use a plier to pull them out and put them back to where they should be. Then you just give it a firm push and it will snap back on.
n7don_srx
03-22-09, 08:15 AM
Thanks.... appreciate the reply. I was concerned about prying it off but couldn't see any other attachments. The 07 removal is the same as your 05
FWIW the rear wiper/washer switch has a 4 terminal blade-type connector. The yellow wire is a low amperage switched 12v source from one of the rear fuse blocks.
