my97deville
03-18-09, 11:10 PM
Need an inexpensive transmission jack or jack to remove the cradle. I use a $120 motorcycle jack. This one is from Sears. Works much better then trying to balance them on a floor jack. These are pictues taken after removing the engine from my 97 Deville to replace the headgaskets. Note: It is important to remove the wheels before raising the engine too high or you will pull the cv shaft apart. I laid 2X6’s on top of the rails of the jack long enough to support the engine cradle. Makes it easy to move around.
48457
48458
48459
When I replaced the transmission in my Sebring it was necessary to build the rails up by using two 2x4’s on one side to fit the bottom of the transmission
48457
48458
48459
