View Full Version : 97 - cranks well, but doesn't start
rladams65
03-16-09, 12:48 AM
I could use some help with the diagnosis -
Here is the sequence of events:
Came out one day and my 97 Catera would not turn over. Even with jumper cables - it would just sort of grunt a 1/2 turn and then do nothing.
After reading this forum I have done the following -
** Replaced the starter (not sure I really needed that - but it made sense at the time)
** Replaced the Crank Shaft Position Sensor
Now I have a car which cranks like a champ, but won't start. Lots of crank, a little bit of rumble, but no start. And NO DTC codes for me to scan (I borrowed the tool from AutoZone since I can't drive the car).
The only 2 things I have not done is change the battery and the positive battery cable.
I have the 3 volume set of factory manuals, but I am running out of ideas to explore.
Any thoughts? Thanks in advance.
98 Catera
03-16-09, 07:59 PM
im thinkin broken timing belt????
