View Full Version : what kind of tranny Fluid?? 94 FWB
bluesteve1
03-15-09, 02:24 PM
changing the radiator and some tranny fluid came out. Just wondering what kind it uses? is it bad to mix them? it's a 94 FWB
thanx
jayoldschool
03-16-09, 11:44 AM
Regular ATF. Not "F" type.
submariner409
03-16-09, 12:11 PM
GM used DEXRON-III and is now retrofilling all service units with DEXRON-VI, a new full-synthetic fluid that is 100% backwards compatible with -III.
Make sure you understand the required fluid level check procedure for your transmission. There are differences.
mjs182004
03-17-09, 04:08 PM
good write up ^^^^, and it is not ok to mix tranny fluid with coolant. the coolant will destroy your transmission. it eats away at the clutch discs and sooner or later the tranny will start slipping.
