View Full Version : 1997 Sts Rear seat removal
BlakesAuto
03-13-09, 11:32 AM
I would like some more info on removing the top part of the back seat in the 1997 STS. The bottom is out and the nuts are removed. The seat just seams to be stuck where it is. The top is where I am having the problems. I figures it should have hooks with the seat wire ran in it and you could just pull the seat up but it isn't moving.
Any Help would be nice.
Thanks
Marty
BlakesAuto
03-16-09, 09:44 AM
I guess no one has ever removed one before. I can't tell if there are bolts on the top or just clips.
timothyr
03-16-09, 01:42 PM
there are two bolts in the upper corners in front of the trunk hinges directly above the rear wheel wells....they should require a 10mm deep socket, and be careful because they are easy to break, they will bind up and the friction will create heat causeing them to snap
