View Full Version : 95 fwb
75sled
03-11-09, 12:56 PM
Is there something common on a 95 FWB that would make it idle rough. The car runs out really smooth, but when sitting it is a little rough. I am considering this car for purchase, but I didn't want to inherit a major problem like burnt valves or something like that.
Just wondering if there was some common, inexpensive fix possible based on someone's experience.
dirt_cheap_fleetwood
03-11-09, 03:21 PM
Opti-spark.
75sled
03-11-09, 04:01 PM
Is it something you can disasemble and correct the problem like a rebuild or do you have to just replace it with a new one?
03-12-09, 01:14 AM
Someone with more LT1 experience should chime in here but it sounds like opti-spark to me. It is a very common failure on the LT1 engines. It must be completely replaced and most people do the water pump at the same time because it takes a fair amount of tear down to get to.
Cadillacboy
03-13-09, 07:15 PM
Beware PCM codes as well to verfiy an Opti Spark issue
