: How do I remove door panel???
jrs05caddyext
03-10-09, 08:57 PM
Does anyone have a diagram on removing the driver side door panel? Thanks
ESCALADOR
03-10-09, 09:42 PM
this is 2005. hope it helps
http://i39.photobucket.com/albums/e168/jlloyd5666/escaldoor.gif
# Remove the door handle bezel. Refer to Handle Bezel Replacement - Inside .
# Remove the door trim panel upper extension. Refer to Trim Panel Replacement - Upper Extension .
# Using a suitable flat-bladed tool, gently pry the manual lock lever from the door trim panel.
# Remove the push in fastener (3) at the front edge of the door trim.
# Remove the cap (5) covering the screw on the rear edge of the trim panel.
# Remove the trim panel screws.
* Remove the screw (2) from within the opening where the manual door lock lever resides.
* Remove the screw (4) from the opening in front of the armrest.
* Remove the screw (6) from the rear edge of the trim panel.
# Carefully slide the trim panel (1) up in order to release the retainers from the door.
# Disconnect the electrical connectors.
jrs05caddyext
03-11-09, 11:10 AM
Thanks:thumbsup:
klipsch21
07-21-09, 02:18 AM
not sure what year escalade you have but I found this guide for a 99-00 on how to remove the door panel.
fixpal.net/escalade/front_door_panel/
92WHTSTS
06-05-13, 03:47 PM
Wish someone had the same illustration for a Eldorado, I need to fix some broken clips.
roketsciontist
08-05-14, 09:40 AM
thanks for the instructions
javdog
05-04-16, 01:31 PM
good info
