: Air ride compresser second life.
03-09-09, 03:35 PM
I have swaped out my rear shocks for GTO ones now my question is does anyone know the wiring for the pump up front so I can rig up a switch to power a Train Air Horn? Nashville drivers need a little extra incentive to get the fugk out of my way so I figured a nice loud air horn (maybe also a small tank) should do it powered by my left over air compressor. Shoot I could even plum in a tire nossle to air up my tires and other stuff from time to time.
So what wire is the power and I assume I could also switch the lever in the rear to triger the pump by making it think the rear was low.
Any help or ideas would be welcomed.
03-12-09, 11:46 AM
Post fail... :thepan:
03-12-09, 11:56 AM
You will need a tank and a pressure switch, like on a compressor. Use the wires that go to the motor. No use anymore for the exhaust valve. The larger two of the four wires are the ones you want. Do a search on the internet, you will find instructions for what you are doing.
