: Will OEM CTS-V wheels fit the SRX?
Klei14
03-08-09, 10:28 PM
I know that escalade wheels don't fit the srx because they are a different bolt pattern, but I know the CTS-V wheels are the same bolt pattern. I was just curious if the CTS-V 20 inch wheels would work on the SRX, I know the bolt pattern is the same, I just don't know about the offsets.
Autobahn_Burner
03-09-09, 06:59 AM
CTS is 5-lug application while SRX has its "own" 6-lug bolt circle...
Klei14
03-09-09, 11:56 AM
http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__SPECIAL-OEM-Polished-Cadillac-CTS-V-Forged-Alloy-Wheels_W0QQitemZ200308892051QQadiZ2865QQadnZCarQ20 Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZViewI temQQptZMotors_Car_Truck_Parts_Accessories?hash=it em200308892051&_trksid=p4506.c0.m245&_trkparms=72%3A1171%7C65%3A12%7C39%3A1%7C240%3A131 8
The CTS-V also has a 6 bolt pattern. The wheels look very close to the OEM SRX 20's that I like. I just don't know if these wheels are the right offset for the SRX.
z32drifter
03-09-09, 08:25 PM
Here is a thread with your answer.... BTW those wheels will look great on a SRX
http://www.cadillacforums.com/forums/cadillac-srx-forum/122442-srx-big-brake-kit.html
Klei14
03-09-09, 09:42 PM
THANK YOU, now I know I can get a set of CTS-V wheels!
davlong
03-09-09, 10:55 PM
The STS-V will also fit.
Klei14
03-09-09, 11:22 PM
I looked at those, but they are 19 rear and 18 front. So tires would be alot of money.
jfaz
03-10-09, 10:14 PM
Here is a pic of my '06 N* AWD with 18" STS-Vs on all corners.
Klei14
03-11-09, 12:08 PM
The sts wheels look great, how did you get 4 18's?
jfaz
03-11-09, 06:36 PM
Thanks. Found a guy on Ebay some months back, checked Cadillac dealership size guide and found offsets of STS-V 18's ONLY were same as std SRX 51mm, so I jumped on 'em since I was needing to replace tires at same time (GY ResponsEdge, std tire size).
The Wrench
03-12-09, 06:49 PM
It's interesting that the new '09 CTS V has 5-lug wheels. Cost savings I guess.
DG
AAIIIC
03-14-09, 11:50 AM
I was just curious if the CTS-V 20 inch wheels would work on the SRX...
Your thread title says "OEM CTS-V wheels", but then you ask about 20" wheels. The OEM CTS-V wheels are 18x8.5" +42mm, as are the GM Accessory wheels (the polished twin 7-spokers).
The SRX does not have its own bolt circle, I'm afraid. The CTS-V and STS-V also use the 6x115mm bolt pattern.
Klei14
03-14-09, 02:38 PM
[quote=AAIIIC;1807552]Your thread title says "OEM CTS-V wheels", but then you ask about 20" wheels. The OEM CTS-V wheels are 18x8.5" +42mm, as are the GM Accessory wheels (the polished twin 7-spokers).quote]
Yea, I posted this thread then realized they were 18's not 20's. The reason I thought they were 20's is because they look so close to the OEM SRX 20 inch wheels.
