: What does a flashing check engine light indicate?
AlmostAV
03-06-09, 03:17 PM
Hello,
My check engine light came on a few weeks ago for a malfunctioning clutch position sensor.
While I was driving the other day, the check engine light began to flash. Then stopped. I was wondering what does the flashing indicate?? as I have never seen it flash before...in the past it was always solid....
This couldnt relate to a rich condition in the a/f ratio because the cars adjusting timing cause it thinks the clutch is depressed?
Thanks
nikon
03-06-09, 05:16 PM
flashing usually means an o2 sensor or something similar...you should get it read though.
03-06-09, 05:22 PM
Light Flashing -- A misfire condition has been detected. A misfire increases vehicle emissions and may damage the emission control system on your vehicle. Diagnosis and service may be required.
Generally speaking - if the light is flashing you should get it looked at...
AlmostAV
03-06-09, 06:52 PM
thanks lindsay. It did only flash for maybe 15 seconds, and hasnt done so since. Im having it tuned tomorrow, again, but will go have the codes read first.
CTS-Voodoo
03-07-09, 02:23 AM
On LS engines thats a misfire. Happened when I did some custom wires for one of our trucks. Put a spark plug in just a might too tight and snapped the ceramic which caused it to misfire. Scared the hell out of me.
JonCR96Z
03-07-09, 02:45 AM
Flashing means misfire, which could come from a thousand different things.
ewill3rd
03-07-09, 07:37 AM
EPA regulations dictate that the MIL must flash if a catalyst damaging event is occurring. Typically this means a steady misfire event, that would dump excess fuel into the cats and destroy them. You should be feeling a misfire when this occurs.
It should be looked at post haste.
Slithering_Joe
03-07-09, 09:40 AM
Typically, the light will initially flash to draw attentention. Depending on the severity, it will remain to flash if the fault needs to be addressed immediately. A steady light means a fault has occurred but not as severe. You need to get the trouble code either through OnStar or a OBDII codereader/scanner.
AlmostAV
03-07-09, 02:57 PM
i got it scanned.....no codes relating to this issue (I still have the clutch positioning sensor issue)
NormV
03-07-09, 03:13 PM
Can the scanner display current and history codes? Would be nice to know just in the case. :)
Norm
JoeyDiamond1997
06-30-15, 06:05 PM
My cadillac cts 05 engine light was flashing this morning nd i have 2 problems that might be a non-purge condition or a heater oxygen sensor ? Is this serious ?
darkman
07-01-15, 12:12 AM
Yes, it is serious - see post nos. 3 & 7/
