: Driveshaft bolt torque
heavymetals
03-05-09, 10:34 PM
Besides using locktite blue, anyone know what torque to set the drive shaft 8 mm bolts to?
darkman
03-05-09, 10:46 PM
Prop Shaft CV to differential flange bolt = 44 ft lbs.
Prop Shaft Coupler to differential flange bolt = 63 ft lbs.
The Service Manual shows a pattern (sequence) to tighten the 6 fasteners that is 12 o'clock, 4 o'clock, 8 o'clock, 2 o'clock, 6 o'clock, and 10 o'clock.
heavymetals
03-05-09, 11:02 PM
Thanks!
lollygagger8
03-09-09, 12:28 PM
Ya what Darkman said......star of david pattern while torquing bolts down
silentwig
02-09-13, 03:08 PM
Anybody know the torque for the flex disc coupler to transmission by chance?
darkman
02-09-13, 06:02 PM
The Service Manual says:
Thoroughly clean the threads using denatured alcohol, or equivalent, and allow to dry. Apply threadlocker GM P/N 12345493 (Loctite Red), or equivalent, to the propeller shaft-to-flange bolt. Ensure that there are no gaps in the threadlocker along the length of the filled area of the bolt. Allow the threadlocker to cure approximately 10 minutes before installation.
Tighten the propeller shaft coupler-to-transmission flange bolts and nuts to 85 Nm (63 ft. lbs.) .
silentwig
02-09-13, 06:33 PM
lmao sounds like a didnt install it right. Thanks Darkman
