: Track Pack Availability?
garfin
03-05-09, 08:54 AM
I've tried searching here to see if any info has been posted previously about the Track Pack option (2 piece rotors, red calipers and a differential cooler) that has been mentioned in a couple of media reviews.
I'm hoping someone here might have some definitive information as to if (or when) this may be available.
Thanks in advance.
Regards,
Elie
Dgr8skier
03-07-09, 06:24 PM
I am desperately looking for this as well. I've seen it the car mags but cannot find anything out otherwise I am ordering my V on Monday & my dealer insisits there is no such thing.
RapidRob
03-07-09, 06:43 PM
Thanks in advance.
Regards,
Elie
The only info. I've seen regarding the Track Pack option is that Brembp still has a hold on the rotors, as noted in the following post:
http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/159658-so-when-will-track-brakes-out.html
Rob
garfin
03-08-09, 08:35 AM
Rob
Thanks, Rob!
Been asking some questions and was informed on Friday via a friend at GM... who says the Track Pack was originally supposed to be on the table as an option for MY 2010 but is now a no-go.
Nothing definite at this stage but it looks like there is some discussion currently about free-flow braking options (bigger Brembo's and colored calipers)... no word on the diff cooler.
One of the dealers maintains there is a CTS-V performance rotor kit from GMPP that is made up of cross drilled vented rotors ... fronts and backs.
FWIW, I tried plugging in both part#'s mentioned for brakes from the above thread into the latest online GMPP catalogue and they came up blank.
The Track Pack option would be a great thing to have, but it doesn't look like it's gonna happen.:(
Best regards,
Elie
Nutz
03-08-09, 09:50 AM
Thanks, Rob!
Elie
Don't hold your breath.
Heck don't even hold your nose... Doubt this one's gonna happen anytime soon.
Dgr8skier
03-08-09, 10:02 AM
[QUOTE=RapidRob;1798986]The only info. I've seen regarding the Track Pack option is that Brembp still has a hold on the rotors, as noted in the following post:
THank you for the thread. I would hope that something has been done by now re the track pack & I have read that it does incl the diff cooler
62Jeff
03-08-09, 10:38 AM
All I've come across is this Front and Rear rotor set, but I'm unsure if it's simply a cross-drilled replacement rotor for our existing brakes, or an upgraded rotor. They don't appear to be two piece rotors at any rate.
http://www.crateenginedepot.com/store/CTS-V-Cross_Drilled-Brake-Rotors-Front-88964607-P1596C89.aspx?UserID=7898768&SessionID=7I64loVPPCZfXKtrhsRu
http://www.crateenginedepot.com/store/CTS-V-Cross_Drilled-Brake-Rotors-Rear-88964608-P1597C89.aspx?UserID=7898768&SessionID=7I64loVPPCZfXKtrhsRu
Jeff
v-sam
03-08-09, 10:43 AM
Sorry for the thread jack...when I was instructing a guy in his 09 V 2 weekends ago we kept getting a warning message "diff. fluid too hot reduce speed." The brakes felt pretty solid but he didn't get into them all that much.
thebigjimsho
03-08-09, 11:35 AM
JeffThose are not for the new V. See the stud count?
I thought all V2 rotors were 2 piece. I thought the Track Package brakes were grooved with colored calipers...
thebigjimsho
03-08-09, 11:39 AM
Hey guys, this site says they have 2 piece rotors for the '09V. That may not be accurate, but check if you want. If you're serious, and if they have them, I may have access to a discount code from a friend. I may be able to use that...
http://www.racingbrake.com/CTS_V_FRONT_04_09_p/2114-311.htm
