: Have question reading my vin check
Original786
03-03-09, 08:04 PM
well i got the Vin check back
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 07/21/2005 62 miles 07/21/2009 50062 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/21/2005 62 miles 07/21/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/21/2005 62 miles 07/21/2013 80062 miles
48/50000 FEDERAL EMISSION 07/21/2005 62 miles 07/21/2009 50062 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/30/2008 170377 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 38241 miles
06/30/2008 170377 # N0110 - BATTERY REPLACEMENT 38241 miles
06/29/2008 W16103 # Z2085 - ROADSIDE SERVICE (PREMIUM) 36500 miles
06/28/2008 W09659 # Z2080 - ROADSIDE SERVICE (TOWING) 35 miles
04/27/2006 259621 # H9711 - FRAME, REAR SUPPLEMENTAL BUSHINGS - INSTALL 10030 miles
04/27/2006 259621 # Z7901 - 1-DAY COURTESY TRANSPORTATION 10030 miles
04/20/2006 259092 # Z7901 - 1-DAY COURTESY TRANSPORTATION 9766 miles
08/09/2005 240584 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 983 miles
08/09/2005 240584 # Z7901 - 1-DAY COURTESY TRANSPORTATION 983 miles
07/27/2005 218958 # Z2082 - ROADSIDE SERVICE (FUEL DELIVERY) 507 miles
02/02/2005 088783 # Y0027 - DOOR LATCH FREEZING IN COLD TEMPERATURES - APPLY SUPER LUB 38 miles
09/24/2004 A41989 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Now how do i know that the rear has been changed to 06-07?
Any claims done previously i should be concerned about?
Warranty still exist till 2009 of July, once i get it should i get the car checked on recall or done anything else under manufacture warranty?.
Thanks
Jon
03-03-09, 08:10 PM
Your rear diff has not been changed according to that report.
Original786
03-03-09, 08:48 PM
i heard i can upgrade the rear to a 2006-2007 if i have warranty still available which i do?
the guy also has a kit on his 2005 cts v, which eliminates wheel hop or most of it, will that void the warranty and does that bolt on to the 2006-2007 upgrade rear or do i not need it
CadiBlk
03-03-09, 09:01 PM
The rear differential can't just be switched to the new model even if you have a warranty. Most dealers will require there to be an issue for them to replace it. Some guys have just gone in and told the dealer that they hear the rear diff making a whine and they replace it without question. Others have had lead pipe lock evidence and not find a dealer that will swap them out.
The wheel hop elim kit that is on there bolts up to the rear suspension cradle, not the rear differential. There are some braces that bolt to the differential to help with it grenading, but both models bolt up in the same spot, so anything that bolts onto it will bolt in the same spot too.
That Vin check looks solid from what I know. Most people have had their batteries replaced and it has had the new bushings put in. I never trust my gas gauge after 1/2 tank, it really seems to pour out after that. I don't want to run out of gas like this owner.
Good luck with the search.
CTSV_510
03-03-09, 09:17 PM
That's a really clean history, one of the cleanest I've ever seen here.
Looks good! :thumbsup:
Original786
03-05-09, 03:14 PM
how come i dont have optional code at the end up of my claim history like everyones vin number claim history
any reason?
lusterblade
03-05-09, 04:18 PM
any reason?
No reason except that I was lazy. I sometime don't add the options list for cts-vs because they were all pretty much loaded, with only real option being sunroof and color, and all the option code lists are exactly the same.
The option list is in a table and doesn't correctly copy and paste into the text box, so I have to paste it to excel, organize it and then paste it here.
Original786
03-05-09, 07:00 PM
does all cts v come with equiped with sunroof or no?
Jon
03-05-09, 07:41 PM
no..
