: Does anyone have a recall and TSB list?
ratbike1
03-02-09, 07:59 AM
Anybody have access to this info they'd like to share?
I have a 2005 specifically, but I'm sure this would help a lot of other members as well! :thumbsup:
pearl04
03-02-09, 07:58 PM
Here is the list of TSB's for 2005 Escalade's...If you would like to find out more details on a specific TSB I can provide it for you...hope this helps
Number Date Title
00-00-89-027E 09/29/2008 Interior - Elimination Of Unwanted Odors
08-08-44-010D 09/29/2008 Navigation Radio - Diagnostic Information
01-07-30-032E 09/29/2008 A/T - 4T65E Fluid Leaking From A/T Vent
08-08-46-006 09/25/2008 Audio System - XM(R) Terrestrial Repeater Changes
08089B 09/23/2008 Campaign - Deactivating Analog OnStar(R)
06-08-46-008C 09/18/2008 OnStar(R) - Analog/Digital System Information
04-07-30-017A 09/16/2008 A/T - Revised Cooler Line Fitting/Converter Check Valve
06-08-111-004A 09/15/2008 Body - Exterior Emblem Discoloration/Blistering/Peeling
05-03-10-005D 09/11/2008 Wheels/Tires - Upsized Wheel/Tire Characteristics
06-08-61-003D 09/10/2008 Body/Frame - Underbody Pop/Clunk When Turning
02-08-42-001C 09/05/2008 Lighting - Headlamp Polycarbonate Lens Damage Prevention
08-08-44-028 08/28/2008 Audio - Inadvertent Steering Wheel Button Activation
03-08-48-006E 08/25/2008 A/C - Rear Window Defroster Grid Contact/Tab Repair
08-06-03-009 08/22/2008 Electrical - Wiring Terminal/Connector Repair Info.
08-08-46-004 08/14/2008 OnStar(R) - Aftermarket Device Interference Information
08-08-44-026 08/11/2008 Audio System - Refurbishing Radio Faceplates/Knobs
08-07-30-035 08/08/2008 A/T - Water Or Coolant Contamination Information
05-06-04-022E 08/06/2008 Fuel System - TOP TIER Detergent Gasoline (Canada)
02-06-03-008D 07/21/2008 Charging System - Low Voltage Display/Battery Discharged
07-06-03-009A 07/21/2008 Charging System - Volt Meter Fluctuation Information
05-06-02-001A 07/16/2008 Cooling System, A/C - Aluminum Heater Cores/Radiators
05-03-07-009B 06/27/2008 Alignment - Specifications/Requirements/Recommendations
04-06-04-047H 06/24/2008 Fuel System - 'TOP TIER' Detergent Gasoline Information
08-08-64-011 06/23/2008 Mirrors - Heated Mirror Defrosting Time
08-08-44-023 06/18/2008 Navigation Radio - Adaptation After Radio/Battery R&R
05-00-89-072B 06/17/2008 Engine/Fuel System - Oil/Fuel Additive Information
00-07-30-022D 06/10/2008 A/T - 4L60/65E, No Reverse/2nd or 4th Gear
99-04-20-002E 06/06/2008 Drivetrain - Driveline Clunk Information
07-08-64-022A 06/05/2008 Instruments - Door Mirror Diagnostic Information
08-07-30-027 06/04/2008 A/T - No Movement in Drive or 3rd Gear
08-07-30-008B 06/03/2008 A/T - Diagnostic Information for DTC's P0894/P1870
05-09-41-001B 06/02/2008 Restraints - SRS Lamp ON/Multiple DTC's are Set
08-07-30-026 05/22/2008 A/T - Slight Vehicle Movement In Park At Start Up
07-08-49-020B 05/22/2008 Instruments - IPC Odometer Programming Reference Guide
08-03-10-007 05/16/2008 Tires - Minimizing Damage to TPM Sensors
01-07-30-010C 05/12/2008 A/T - Torque Converter Replacement Information
01-07-30-036G 05/12/2008 A/T - DTC P0756 Diagnostic Hints
08-03-16-003 05/12/2008 Tire Monitor System - TPM Sensor Information
04-06-04-036E 05/08/2008 Emission - Emissions Programming Warranty Coverage
00-05-22-002K 05/06/2008 Disc Brakes - Warranty Service and Procedures
03-07-30-007E 05/05/2008 A/T - Gear Engagement Time Information
01-08-42-001F 05/02/2008 Lighting - Exterior Lamp Condensation Guidelines
03-07-29-004E 05/02/2008 M/T - Operating Characteristics of Manual Transmissions
05-08-46-001D 05/02/2008 OnStar(R) - No Power/Inoperative/No LED
08-07-30-009B 05/01/2008 A/T - 4T80E, Slips in Gear/L/H Axle Seal Leaks
08-03-10-005 05/01/2008 Wheels/Tires - Chrome or Chrome Plated Steel Valve Caps
08-03-10-006 05/01/2008 Wheels/Tires - Tire Slowly Loses Air/Low Tire Message
07-08-49-015C 04/29/2008 Instruments - Odometer/Hour Meter Programming Procedure
02-06-03-009C 04/17/2008 Electrical - Battery Charging Tips/Recommendations
05-06-03-002C 04/17/2008 Battery/Charging System - Electrical Diagnostics Info.
00-06-01-012C 04/14/2008 Engine - Use of 'Surface Conditioning Disks'
08-03-08-003 03/27/2008 Drivetrain - Wheel Hub Changes/Applications
08-06-01-008 03/27/2008 Engine - Accessory Drive Belt Noise Diagnostics/Tool
00-02-35-003N 03/26/2008 Steering - Underhood Clunk Heard/Felt in Steering Wheel
08-03-10-004 03/25/2008 Wheels/Tires - Accessory Wheel/Tire Mounting/Balancing
08-08-51-002 03/12/2008 Body - TPO Fascia Cleaning Prior to Painting
08-08-52-002 02/27/2008 Remote Starting System - System Inoperative Diagnostics
08-09-41-003 02/25/2008 Restraints - Usage of Used/Salvaged/Imitation Components
02-07-30-052E 02/22/2008 Automatic Transmission - Fluid Cooler Flushing
05-00-89-078B 02/06/2008 Fuel System - GM Fuel System Treatment PLUS(R) Info.
04-06-01-029B 02/05/2008 Engine - Crankcase Flushing Information
06-02-32-013A 02/05/2008 Steering - Power Steering Pump Replacement Tips
06-06-04-035A 02/05/2008 Fuel System - E85 Fuel Usage Precaution
01-04-18-001F 02/04/2008 Drivetrain - AWD/4WD System Driveline Characteristics
06-06-01-010A 02/04/2008 Exhaust System - Catalytic Converter Precautions
04-03-10-012B 02/01/2008 Wheels - Chrome Wheel Brake Dust Accumulation/Pitting
00-08-48-005C 02/01/2008 Body - Vehicle Glass Distortion Information
06-08-44-015A 02/01/2008 Audio System - Noise When Using Portable Playback Unit
08-07-30-004 01/31/2008 A/T - Cooler Line Fitting Applications
01-05-23-001B 01/31/2008 Brakes - Rotor Lateral Runout Correction Information
99-08-52-005C 01/30/2008 Keyless Entry System - Characteristics of Operation
05-08-64-032A 01/30/2008 Body - Rear Door Glass Squeal When Rolling Down
08-01-38-001 01/25/2008 A/C - Refrigerant Recovery/Recycling/Equipment
04-08-50-006B 01/25/2008 Interior - Seat Cover Wrinkle/Crease/Crack/Burn Info.
06-01-39-002C 01/18/2008 A/C - Blower Motor Inoperative or Won't Shut OFF
05-06-02-002B 01/18/2008 Cooling System - DEX-COOL(R) Coolant Leak Detection Dye
00-08-46-004C 01/17/2008 OnStar(R) - Re-establishing OnStar(R) Communications
05-03-10-003C 01/15/2008 Wheels/Tires - Low Tire Pressure
00-03-10-006C 01/09/2008 Tires - (RFV) Radial Force Variation Information
99-09-40-005E 01/09/2008 Seat Belts - Seat Belt Extender Availability
05-08-46-004B 01/08/2008 OnStar(R) - Number Incorrect/Incorrectly Assigned
02-08-46-006C 01/08/2008 OnStar(R) - Incorrect GPS Position Reported During Call
02-08-44-007C 01/08/2008 OnStar(R) - Negative Impact of Cloth/Vinyl Roofs
04-03-10-001D 01/07/2008 Tires - Tire Puncture Repair Procedures
05-03-10-020A 01/03/2008 Tires - Nitrogen Gas Usage
03-06-04-030F 12/10/2007 Fuel System - MIL ON/Driveability Issues
04-07-30-037D 11/21/2007 A/T - DEXRON(R)-VI Fluid Information
02-08-46-007C 11/19/2007 OnStar(R) - Loss of GPS Signal/Hands Free Issues
02-01-39-007B 11/05/2007 A/C - Battery Draw Information
03-00-89-008D 11/02/2007 Body - Metal Body Panel Corrosion Protection
07-09-40-002 10/31/2007 Restraints - Seat Belt Latch Stop Button Availability
00-00-90-002I 10/23/2007 Tires/Wheels - Tire Inflation Pressure Information
05-06-01-010B 09/28/2007 Engine - Sealant Usage/Procedures
07-07-30-024 09/27/2007 A/T - Valve Body Reconditioning
03-03-10-007C 09/21/2007 Tires/Wheels - Vibration/Balance/Shake/Flat Spotting
07-06-01-016A 09/17/2007 Engine - Internal Noise/Damage After Oil Filter Change
07-08-45-002 09/05/2007 Electrical - Aftermarket Fuse Warning
07-08-44-016A 08/28/2007 Entertainment System - DVD Monitor Display Inoperative
03-06-03-001D 08/02/2007 Starting System - Starter Cranks After Key Released
07-08-44-014 08/01/2007 Navigation Radio - CD Error Message Displayed
05-06-04-035C 07/30/2007 Fuel System - E85 Fuel Usage Precautions
06-08-50-009B 07/19/2007 Restraints - Front Passenger Seat Accessory Precautions
05-08-44-005A 07/19/2007 Entertainment System - Headphone Foam Pad Replacement
05-02-32-008B 07/18/2007 Steering - Lack of Assist at Low Speeds
99-08-64-016B 06/22/2007 Body - Use of Silicone for Weatherstrip Maintenance
00-06-01-026B 06/21/2007 Intake Manifold - Inspect/Replace After Engine Damage
07-06-04-019 06/21/2007 Engine Controls - MIL ON/Reduced Power/DTC P2138
03-03-16-001A 06/21/2007 Tire Monitor System - DTC's C0760/C0765
03-08-64-010C 06/18/2007 Body - Rearview Mirrors Blow In At Highway Speeds
04-05-25-002D 06/14/2007 Brakes - ABS Lamp ON/DTC's C0265/C0201/U1041
05-09-40-002B 06/13/2007 Restraints - Seat Belt Normal Locking Conditions
06-08-43-003A 06/08/2007 Wipers - Performance/Cleaning Instructions/Maintenance
99-01-39-004B 05/29/2007 A/C - Odors In Hot/Humid Conditions
01-07-30-042E 05/21/2007 A/T - 2-3 Upshift or 3-2 Downshift Clunk Noise
07-07-30-010 05/03/2007 A/T Controls - Snapshot Data Information
07-07-30-008 05/01/2007 A/T - 4L60-E/4L65-E/4L70-E Production Update
05-08-51-008B 04/23/2007 Body - Bumps or Rust Colored Spots in Paint
07-08-44-007 04/17/2007 Navigation System - Replacement Navigation Discs
07-08-63-001 04/17/2007 Body - Polypropylene Energy Absorber Replacement
01-06-01-011D 04/03/2007 Engine - Oil Consumption Guideline Info.
07-08-98-001 04/02/2007 Body - Non-Approval of 'Clipping' for Collision Repair
07-01-37-002 03/30/2007 A/C - Coolant Leak at Rear of Vehicle
02-08-42-004A 03/30/2007 Instruments - Reduced PRNDL Display Visibility
07-06-01-002 03/05/2007 Engine - Revised Connecting Rod Bolt Torque
03-06-05-008D 03/05/2007 Exhaust System - Popping/Snapping Noise When Hot/Idling
04-01-39-009C 02/28/2007 A/C - Blower Motor Inop. - BULLETIN CANCELLED
04-07-30-013B 02/01/2007 Engine, A/T - Shift/Driveability Concerns/MIL ON
06-00-89-051A 01/24/2007 Locks - Key Code Securtiy Rules & Information
02-08-98-002B 01/17/2007 Body - Hem Flange Repair
06-01-39-015A 01/12/2007 A/C - No Rear Temp Control/Noise/DTC's B0434 or B3764
04-06-04-054A 01/11/2007 Engine Controls - Aftermarket Accessory Usage
05-07-30-018A 01/11/2007 A/T - Cold Weather Shift Characteristics
06-00-89-054 11/30/2006 Warranty - Claims Submission
06-05-22-007 11/30/2006 Brakes - Rotor/Drum Refinishing Labor Operations
06-00-89-050 11/22/2006 Warranty - DTC's Required On Repair Orders
04-08-49-015A 11/06/2006 Instruments - Noises From The Instrument Cluster
01-07-31-002B 11/01/2006 M/T - Hydraulic Clutch Bleeding Procedure Improvement
00-06-04-033B 10/10/2006 Emissions - OBDII I/M Readiness Testing
02-08-98-001C 10/09/2006 Body - Metal Panel Adhesive Bonding Information
06-08-48-002 10/05/2006 Body - New Design Back Glass Availability
06-06-04-046 09/12/2006 Engine Controls - MIL ON/Misfire/Misfire DTC's Set
01-07-30-038D 09/12/2006 A/T - Poor Performance/MIL ON/DTC P0757
06-03-10-010 09/07/2006 Wheels - Changing Procedures/Precautions
02-03-10-001C 08/28/2006 Tires - Spare Tire Different Size Than Other Tires
06-07-30-017A 08/16/2006 A/T - 4L60-E/4L65-E/4L70-E Whine/Whistle/Chirp Noise
06-08-44-018A 08/16/2006 Audio - CD Changer Clicking Noise When Initialized
00-06-02-006D 08/15/2006 Cooling System - Coolant Recycling Information
06-06-04-037 08/04/2006 Engine Controls - MIL Function During I/M Testing
00-03-10-002D 08/01/2006 Wheels Chrome Wheel Chemical Staining/Pitting/Corrosion
06-01-39-007 07/25/2006 A/C - Contaminated R134A Refrigerant
05-08-50-012A 07/24/2006 Interior - Loose/Unwanted Seat Movement
99-08-51-007C 06/19/2006 Wheels - Aluminum Wheel Refinishing Recommendations
04-07-30-037B 06/12/2006 A/T - DEXRON(R) VI Fluid Availability
06-08-111-002 05/26/2006 Body - Upper Liftgate Molding Rubs Roof When Opening
03-07-30-043A 05/25/2006 A/T - Shift Lock Control Feature Function
06-04-21-001 05/17/2006 Drivetrain - Updated Transfer Case Speed Sensor Conn.
03-05-25-007C 05/16/2006 Brakes - Low Speed ABS Activation/No DTC's Set
06-06-04-030 05/15/2006 Fuel System - E85 Refueling Station Information
05-07-30-028A 05/08/2006 A/T - 4L60-E/4L65-E/4L70-E Product Updates
06-08-45-004 05/02/2006 Electrical - Instrument Panel & General Wiring Repair
06-01-38-003 04/27/2006 A/C - Ticking Noise From Instrument Panel/DTC's Set
05-08-64-002B 04/03/2006 Body - Door Latches Freezes in Extreme Cold
02-08-48-001B 03/29/2006 Body - Urethane Adhesives for Glass Applications
06-01-38-002 03/17/2006 A/C - Hiss Noise From Instrument Panel
06-03-08-002 03/09/2006 Suspension - Revised Upper Control Arm Replacement
02-06-04-015A 03/07/2006 Starting System - Engine No Start/No Crank Condition
02-08-46-010G 03/01/2006 OnStar(R) - Programming for Canadian French
06-03-10-004 03/01/2006 Tires/Wheels - Wheel Weight Usage Precautions
05-05-25-003B 02/22/2006 TCS/ABS - Service Stability Message/Multiple DTC's Set
05-07-30-017B 02/17/2006 A/T - 4L60-E/4L65-E/4L70-E Shudder/Water in Transmission
05-08-64-029B 02/16/2006 Body - Window Regulator Replacement
02-06-05-004B 02/14/2006 Accessories - DTC's P0300, P1380, P1381
05-08-44-029A 02/13/2006 Audio System - Radio Knob Availability
04-08-46-002B 02/07/2006 OnStar(R) - Unable to Connect, Bulletin Cancellation
05-02-35-003B 01/27/2006 Body/Steering - Clunk Noise When Turning
03-08-50-014A 01/20/2006 Electrical - No Module Communication/DTCs/Warning Lamps
03-08-44-018C 01/09/2006 A/C/Audio System - Rear A/C, Audio Inoperative
04-06-04-051B 01/04/2006 Fuel System - Fuel Injector Maintenance Cleaning
pearl04
03-02-09, 07:59 PM
The list was too long to post all together so here is the other half.
Number Date Title
03-04-17-001E 12/22/2005 Drivetrain - Rear Diferential Whining Noise at 45-60 MPH
05-09-41-010 12/22/2005 SRS - New SIR System Disabling Procedure
05-08-50-017 12/14/2005 Interior - Power Seat Switch Knobs Loose/Missing
05-08-64-038 11/21/2005 Body - Rubbing/Scratching When Operating Windows
99-08-51-001A 11/21/2005 Body - Paint-Less Dent Repair Recommendations
04-03-10-007E 11/17/2005 Tires and Wheels - 20 Inch Wheel/Tire Availability
05-00-90-010 11/17/2005 Drivetrain - Front Drive Axle Lubrication Update
02-01-39-004B 11/16/2005 A/C - New PAG Oil
04-08-44-020C 11/09/2005 Audio System - CD Player Long Load Time/Error Message
04-08-126-001A 10/21/2005 Navigation System - Navigation DVD Upgrade
01-07-30-030B 10/18/2005 A/T - 4L60-E/4L65-E Harsh 1-2 Upshift Diagnosis
01-07-30-041B 10/06/2005 A/T - Diagnosing Fluid Leaks
05-05-25-008 10/05/2005 ABS - 'Service Stabilitrak(R)' Message/DTC C0455 Set
05-08-67-002A 09/28/2005 Body - Sunroof Won't Close
05-06-04-060 09/23/2005 Engine, A/T Controls - Shared Diagnostic Trouble Codes
01-07-30-002E 09/23/2005 Electrical - A/T Stuck in 2nd/3rd Gear/MIL ON/DTC's
05-08-44-028 09/23/2005 Audio System - CD Changer Clicks/Freezes Up
05-08-44-026B 09/12/2005 Audio/Navigation System - Display Dims/Goes Blank
04-08-45-008B 09/02/2005 Instruments - Outside Temperature Reads Too High
05-08-50-008 08/19/2005 Interior - Intermittent Seat Heater Operation
05-08-05-008 08/18/2005 Interior - Heated Seats Intermittently Inoperative
02-07-30-024B 08/18/2005 A/T - Cracked Case Diagnosis
04-08-50-016C 08/12/2005 Interior - Erratic Memory Seat Operation
03-06-04-012A 08/10/2005 Electrical - Harness Connection Inspection
05-06-04-043A 08/02/2005 Fuel System/Body - Fuel Filler Cap Tether Too Short
04-08-48-001B 06/28/2005 A/C - Broken Rear Window Defogger Grid Detection
05-03-16-002 06/20/2005 Tire Monitor System - System Messages
05-08-42-008 06/10/2005 Lighting - Fog Lamp Bulb Replacement Precaution
05-02-35-003 06/03/2005 Body/Steering - Clunk From Front of Vehicle on Turns
05047 05/16/2005 Campaign - Child Restraint Owners Manual Update
02-08-67-009A 05/16/2005 Body - Sunroof Jams Upon Closing
05-07-30-012 05/09/2005 Engine Controls - 4L60E/4L65E A/T, 2-3 Shift Clunk Noise
05-07-30-013 05/09/2005 Engine Controls - 4L60E/4L65E A/T 2nd Gear Start
05-06-01-014 05/09/2005 Engine - Oil Leaks In Extreme Cold Temperatures
05-08-61-005 04/29/2005 Body/Frame - Revised Crossmember/Body Bolt Service
NHTSA05V163000 04/22/2005 Recall 05V163000: 2nd Row Seat Belt Modification
05-03-10-004 04/19/2005 Tire Monitor System - Tire Mounting/Dismounting Cautions
05-08-49-010A 04/18/2005 Engine Controls - Battery Lamp ON After PCM Replacement
00-08-46-002A 04/12/2005 OnStar(R) - Cellular Antenna Replacement Parts
01-05-26-001A 04/08/2005 Brakes - Low Effort Parking Brake System Information
02-03-07-002A 03/24/2005 Steering/Suspension - Revised Caster/Camber Adjustment
03-05-24-001A 03/21/2005 Brakes - Wheel Cylinder Inspection Guidelines
05-06-04-024 03/17/2005 Engine Controls - Revised DTC P1172 & P2636
05-08-42-003 03/11/2005 Lighting - HID Headlamp Disposal Instructions
05-04-21-002 03/10/2005 Drivetrain - Transfer Case Control Module Replacement
05-04-21-001 03/08/2005 Transfer Case - RTV Silicone Sealant Usage Precaution
05023 02/11/2005 Recall - Shift Lever Postion Indicator Non-Compliance
00-07-30-009A 02/09/2005 A/T - New/Reman A/T Identification
00-08-46-003B 02/09/2005 Instruments - GPS System Performance Degradation
02-05-26-001C 01/19/2005 Brakes - Park Brake Shoe Retaining Clip Kit
05-08-143-001 01/13/2005 Interior - Erratic Adjustable Pedal Operation/DTC B3606
04-08-49-006C 01/05/2005 ABS/TCS - Service Stability Message/DTC C0550 Set
04-08-46-005 12/21/2004 OnStar(R) - System Inoperative/No LED Lamp ON
04-06-03-016 12/13/2004 Battery - Specification Label Clarification
04-03-16-003 11/30/2004 Tires - Go Flat Slowly/Low Tire Lamp ON
04-01-38-018 11/30/2004 A/C - HVAC Module External Seal Kit Availability
03-08-98-002A 10/11/2004 Body - Squeeze Type Resistance Spot Welding/Equipment
04-08-50-014A 09/03/2004 Interior/A/C - Poor Seat Cooling Performance
01-01-38-006D 09/01/2004 A/C - R-134a System Flushing Procedures
04-08-68-002 09/01/2004 Cruise Control - Increasing Set Speed
04-08-57-005 08/31/2004 Body/Interior - Water Intrusion Into Cab From Midgate
04-01-38-010 08/09/2004 A/C - Low Pressure Switch Diagnosis
03-08-49-017A 08/03/2004 Interior - Console Cupholder/Ashtray Cover Won't Close
02-06-03-010A 07/02/2004 Battery - Parasitic Drain
04-06-00-047 06/24/2004 Fuel - Top Tier Detergent Gasoline Information
04-01-38-008 06/17/2004 A/C - Defaults To Defrost Mode/Poor Control
NHTSA05V055000 02/14/2004 Recall 05V055000: A/T Shift Indicator Defect
89358 11/01/1988 Battery - Diagnosis and Charging
fasteddyII
03-02-09, 08:20 PM
Stupid question but if the warranty is out can you take a vehicle in for any of these?
03whiteesv
03-03-09, 02:07 AM
how about this one: http://repairpal.com/cadillac-escalade-2005
ratbike1
03-03-09, 07:23 AM
Thanks so much Pearl04; great post!!
ewill3rd
03-03-09, 08:26 AM
Having a list of TSBs for the year and make of your car is worthless.
TSBs are designed to help diagnose cars, not to justify problems you think you have.
TSB information is a diganostic aid not an excuse to beat your dealer over the head. You bring the car in and tell us what is wrong and we match your symptoms to bulletins. It is easier now than it used to be because of the electronic format.
Recalls or Campaigns are mostly covered items for as long as you own your vehicle. Some have limits depending on the nature of the issue.
Special policies always have time/mileage limits but are paid for if you are within the limits outlined in the documentation.
Also just because a certain year has a recall doesn't mean they are all affected. The recall must be verified in GM's system before the work can be performed.
ratbike1
03-03-09, 09:18 AM
:hide:
I'm sure you work at an amazing dealer that does everything the right way the first time; however I'm sure there are several of us on the forum who have had less than stellar experiences with others.
I've had TSBs come in very handy when trying to have problems taken care of under warranty.
In fact, I was denied any resolution to my graying bed covers until I presented my service manager with the TSB which called for the Gatorback treatment, and it performed shortly therafter. Please note; I said presented and not beat over the head! ;)
joee5
03-03-09, 01:17 PM
In this day and age every advantage, we as consumers get the better, to keep our vehicles running in tip-top shape longer. God Bless, Joe
joee5
03-03-09, 01:25 PM
What an awesome post. I just got done checking out the repairpal site and it is very informative. Thanks for sharing. God Bless, Joe
